Thread started 11 Oct 2007 (Thursday) 08:29
Canon 40D-Shooting Raw-Which Functions Matter?
expatdude
Oct 11, 2007 08:29 |  #1
I always shoot raw, so I always shoot with auto white balance because I understand that I can correct any problems with raw software. Is this a correct understanding? In the same vein, if you shoot raw, do Picture Styles make any difference at all? Does the camera apply any sharpening, etc. to raw pics? Another one: does it matter if I have noise reduction on or off when I shoot raw? How about any other functions--which ones matter and which ones don't in Raw. Thanks in advance for any help on this.
Jon_Doh
Oct 11, 2007 08:36 |  #2
If you shoot in Raw then none of the picture styles or in camera sharpening will be applied. If you have a large enough memory card you can shoot Raw + Jpeg. I've modified one of the picture styles and shoot Jpeg for snapshots and I really like the result it gives me. But when I'm shooting something I really want to blow up I'll shoot in Raw. As for white balance you can make adjustments in DPP or Photoshop (including Elements) before you convert the file. You'll find auto doesn't do a very good job and that you'll need to either apply an adjustment in via software or on the camera for best results.
I use a Kodak Brownie
Doug ­ Pardee
Oct 11, 2007 11:16 |  #3
The answer for the Digital Rebel series (external link), from the Digital Rebel FAQ.
The 40D should be basically the same as the XTi/400D, although I'm not au fait with all of the added functionality. I do know that Highlight Tone Priority affects exposure and thus the raw data; HTP relies on Canon Raw converters (RIT or DPP) to adjust for the reduced exposure. An HTP Raw file will look quite dark in a non-Canon converter such as ACR that doesn't understand HTP.
mike397
Oct 11, 2007 13:45 as a reply to  @ Doug Pardee's post |  #4
Doug,
Excellent article ,thanks for the link.
I looked at some of your shots.....really great.,nice color,excellent composition.
Mike
Canon 24-105L ,,Voigtlander 40mm & Apo Lanthar 90mm macro...,Nikon 55mm f2.8 micro ,Leica 60mm f2.8 macro ,Leica 180mm f4, Zeiss c/y 135mm f2.8 ,Olympus 21mm f3.5
http://mike397x.zenfol​io.com/ (external link)
brimacx
Joined Feb 2006
Oct 11, 2007 16:14 |  #5
only when using DPP to open the RAW files will the camera settings apply - not in Adobe Camera Raw.
7D * 50 f/1.8 mII * 100 f/2.8 macro * EF-S 17-55 IS * 70-200 f/2.8L IS II * 550 EX Speedlight * Tamron 1.4x AF SP TC * Canon 12mm Extension tube * Canon 2X-TC mkIII
racingsafetyman
Oct 12, 2007 06:17 |  #6
brimacx wrote in post #4107273 (external link)
Then what information does Adobe Camera Raw pick up to use as it's base RAW data? It's just that if the picture styles affect the RAW image in DPP, which they do, there is no "off" setting, unless this is the "Neutral" or "Faithful" setting - both of which have different effects on the image?
Colin
My Gear List
http://www.colantra.sm​ugmug.com (external link)
EOSAddict
Book Committee Immortal
Oct 12, 2007 07:46 |  #7
What you set in-camera will also show on the LCD preview regardless of RAW or not... so if you use LCD to check exposure beware!
Al
My Gear, My Website: www.endofthetrailphoto​graphy.com (external link)
tzalman
Fatal attraction.
Oct 12, 2007 08:53 |  #8
racingsafetyman wrote in post #4110425 (external link)
Every converter has to use some default values for its initial conversion. Without them there can be no image on your screen because a Raw file is not a RGB image file. DPP uses defaults that attempt to mimic the camera's settings for jpgs. Other converters use defaults derived from their authors' judgement of what constitutes a good starting point for further editing and each one is, therefore, different. The concept of an "off" setting, a conversion without some set of default values having been applied to it, is impossible unless you are willing to accept a un-white-balanced linear conversion which would be dark and green-casted.
Elie / אלי
racingsafetyman
Oct 12, 2007 16:54 |  #9
tzalman wrote in post #4110872 (external link)
OK that makes sense to me, meaning that there is no such thing as a "RAW" image which hasn't had some form of conversion before it is transformed to JPEG regardless of which raw viewer you choose. Thanks.
Colin
My Gear List
1,630 views & 0 likes for this thread, 8 members have posted to it.
2872 guests, 156 members online
