I am using my joy stick on my 30D to move the focal points around. I like it alot better then using the wheel EXCEPT, I cant figure out how to select ALL the focal points using the joy stick...any hints?
superdiver Cream of the Crop 9,862 posts Likes: 5 Joined Jan 2006 Location: Ketchikan Alaska More info | Oct 11, 2007 16:22 | #1 I am using my joy stick on my 30D to move the focal points around. I like it alot better then using the wheel EXCEPT, I cant figure out how to select ALL the focal points using the joy stick...any hints? 40D, davidalbertsonphotography.com
Hermeto Cream of the Crop 6,674 posts Likes: 2 Joined Oct 2005 Location: Toronto, Canada More info | Oct 11, 2007 16:31 | #2 Permanent banI am not sure how it works on 30D, but on 40D, each time you press joystick directly down, it toggles between Center point and All points. What we see depends mainly on what we look for.
superdiver THREAD STARTER Cream of the Crop 9,862 posts Likes: 5 Joined Jan 2006 Location: Ketchikan Alaska More info | Oct 11, 2007 16:36 | #3 I think I tried that but I will try again...Not that I have EVER been wrong before...LOL 40D, davidalbertsonphotography.com
DougPardee Senior Member 838 posts Joined Feb 2007 Location: Southern California, USA More info | Oct 11, 2007 16:43 | #4 From page 77 of the 30D manual: "If you press the multicontroller in the same direction as the currently-selected AF point, all the AF points will light and automatic AF point selection will be set."
superdiver THREAD STARTER Cream of the Crop 9,862 posts Likes: 5 Joined Jan 2006 Location: Ketchikan Alaska More info | Oct 11, 2007 16:48 | #5 I will try it again....I thought I tried that... 40D, davidalbertsonphotography.com
kcbrown Cream of the Crop 5,384 posts Likes: 2 Joined Mar 2007 Location: Silicon Valley More info | Oct 11, 2007 17:21 | #6 Superdiver, try pressing the focus point select activation button, which is the rightmost button on the back of the camera. When the camera is set up to use the joystick for focus point selection, that button will cause them all to be selected. "There are some things that money can't buy, but they aren't Ls and aren't worth having" -- Shooter-boy
superdiver THREAD STARTER Cream of the Crop 9,862 posts Likes: 5 Joined Jan 2006 Location: Ketchikan Alaska More info | Oct 11, 2007 19:29 | #7 So I went out to the car and tried it. It doesnt work when you push the stick to the same position it is in (I thought I had treid that...LOL), but what did work was to push the button as kcbrown recomended...Thanks... 40D, davidalbertsonphotography.com
| Latest registered member was a spammer, and banned as such! 2869 guests, 156 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
