HI I HAVE A 5 D AND BROUGHT THE 40D FOR BACK UP .i found the 40 d when it dose focas it dosent show it in the vew .Then i take the photo look at the photo and it is in focas .Is this right dose any one else have this problem thanks karen
BEWITCHED Senior Member 252 posts Joined May 2007 More info | Oct 11, 2007 16:57 | #1 HI I HAVE A 5 D AND BROUGHT THE 40D FOR BACK UP .i found the 40 d when it dose focas it dosent show it in the vew .Then i take the photo look at the photo and it is in focas .Is this right dose any one else have this problem thanks karen
spphoto Senior Member 387 posts Joined Jan 2007 Location: Vancouver Island, BC More info | Oct 11, 2007 17:14 | #2 Check your settings, I know with the 20 and 30 you can change how it shows the focus. Also, if it's in an AI mode and you don' have a specific focus point selected, it won't show which it uses. ~ Stefanie Pletscher
Oct 11, 2007 17:26 | #3 BEWITCHED, Sony A6400, A6500, Apeman A80, & a bunch of Lenses.............
::John:: Cream of the Crop More info | Oct 11, 2007 17:30 | #4 Check the dioptor adjustment in the viewfinder, too. I am the proud owner of the Peleng 8mm Fisheye lens
amonline Goldmember 3,558 posts Likes: 1 Joined Jul 2006 More info | Oct 11, 2007 17:35 | #5 Sounds like you have the focus indicator/confirmation off.
Oct 11, 2007 17:43 | #6 Thank you so much great help ill go and see if i can fix the problem:o
Oct 11, 2007 17:54 | #7 ::John:: wrote in post #4107618 Check the dioptor adjustment in the viewfinder, too. If that is not adjusted for your eyesight, the camera will be taking focused shots - but they may look OOF to you at the time. THANK YOU THANK YOUR RIGHT ON I LEARN SOME THING NEW EVERY DAY , I will start to en joy my 40 D THANKS TO YOU
::John:: Cream of the Crop More info | Oct 11, 2007 18:00 | #8 Happy to have helped. I am the proud owner of the Peleng 8mm Fisheye lens
| Latest registered member was a spammer, and banned as such! 1614 guests, 135 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
