Thread started 12 Oct 2007 (Friday) 05:38
Monopod and IS
Wayne ­ Photography
Oct 12, 2007 05:38 |  #1
I always shoot my weddings with a monopod,and have not had any problems as of yet,but a friend said that using image stabalized lenses on a monopod should be switched off like you do on a tripod bycause you get blured images..
This has really got me a bit nervous now although I have'nt seemed to have problem yet..is there anyone who can answer this question for me..
thanks.
Canon 40D
580 ex
canon 70-200mm 2.8 L is
canon 17-85mm ultrasonic is
And a load of other stuff............
amonline
Oct 12, 2007 06:15 |  #2
It really kind of depends on the situation in terms of light and how fast you usually shoot. Personally, I shoot w/ IS off whenever I think I can. On a monopod, I would probably very rarely use IS. In general, your friend's kind of right if you find yourself shooting in the 1/200 range at lower/mid ISO's. If you do not need it, it's eating battery. ;)
highway0691
Oct 12, 2007 07:57 |  #3
I can remember reading in one of the IS lens manuals (70-200 f2.8 IS)that the IS does not work when a tripod/monopod is attached to the lens via the ring attachment, this is what you're friend is probably talking about.
Cheers
Damian
There is nothing worse than a sharp image of a fuzzy concept. Ansell Adams
amonline
Oct 12, 2007 08:36 |  #4
While all Canon manuals "recommend that IS be turned off while tripod mounted", it doesn't mean IS won't work. Ask any motorsports photographer. ;)
highway0691
Oct 12, 2007 09:15 |  #5
Quoting directly from the canon EF70-200mm F2.8L IS USM manual, Canon states;
"Set the STABILIZER switch to OFF when you are taking pictures with a tripod. Even if the STABILISER switch is set to ON, the IS fuction does not operate because the electronic circuits in the lens automatically detect that a tripod is being used."
Cheers
Damian
Richtherookie
Oct 12, 2007 09:29 |  #6
I just ran out and put mine on a monopod, i could feel the IS working. I keep my IS on all the time, never have seen negative results, however I am still pretty new to this, so i am sure a pro could see a difference.
I would think that if your glass is held still by the pod that when the IS kicks in that the motor would vibrate a little, to a good eye it may be picked up, or i could see a picture of the moon or distant item would make it stand out more. I mean come people use mirror lock up!
You got me wondering about it now, thanks. I have something to check out on lunch hour.
Canon 40D, Rebel XT, Kit lens, EF 70-200mm f/2.8L IS USM, 50mm F/1.8II, 28-135mm 3.5-5.6 IS USM
Trained to survive, willing not to.
www.haysphotography.ne​t (external link)
highway0691
Oct 12, 2007 09:38 |  #7
The plot thickens. I kept reading the manual and it also states "The stabiliser is equally effective for hand-held photography and photography with a monopod" There seems to be some ambiguity here when considering my previous quote from the manual. How can the lens tell the difference from a tripod and a monopod as the manual indicates that the lens IS behaves differently for each?
Cheers
damian
Richtherookie
Oct 12, 2007 12:07 |  #8
unless there is something internal in the lens. Pulled my tripod ring off my glass and see no signs of anything to tell the lens anything at all. I would have to believe that is it knew at all it would because the IS sensor detect that the lans is stable. I still have to believe that the vibration of the motor WOULD cause some shake to the system. But my question would be how much shake/blur would it cause? I didn't have enough time on lunch to try it, will spend some time this week end looking though. I have to believe that someone in this forum has proved this one way or the other by now.
amonline
Oct 12, 2007 12:16 |  #9
highway0691 wrote in post #4111060 (external link)
Cheers
damian
It can't. Try it. ;)
Jon ­ Rouston
Oct 12, 2007 12:33 |  #10
Is it because a tripod doesn't move AT ALL
Whereas a monopod will shake a bit, especially as you try to ramp up the SS
Wedding Photographer based in Nottingham, UK (external link)
A few black boxes | some long tubes with glass in them | small boxes that make bright lights
amonline
Oct 12, 2007 13:05 |  #11
No matter what, if you have IS on it will engage - even if briefly - in any situation. At least, mine always have. ;)
Wayne ­ Photography
Oct 12, 2007 15:07 |  #12
Hi ppl..
Thanx for the gret response to my question ..I will have to do some shooting tests and see if there is a difference..once again thanks.
Wayne
Canon 40D
580 ex
931 views & 0 likes for this thread, 5 members have posted to it.
Monopod and IS
1614 guests, 135 members online
