Canon EF 28-135MM F/3.5-5.6 USM Image Stabiliz
getting a good deal on this lens .. i do modeling photos will it work for me
i'm new to this??
gilphx Member 116 posts Joined Oct 2007 More info | Oct 12, 2007 14:50 | #1 Canon EF 28-135MM F/3.5-5.6 USM Image Stabiliz
WildWolf Goldmember 1,022 posts Likes: 4 Joined Feb 2003 Location: NY More info | Oct 12, 2007 15:06 | #2 u will need to stop it down a bunch but it will work 5DMkIV
stop it down? i'll figure out what that means,... but is it a hassle
Bbryan5 Member 210 posts Likes: 1 Joined Jun 2007 Location: jersey More info | Oct 12, 2007 15:09 | #4 You'd have a better response in the Lens forum... Bryan
Familiaphoto Goldmember 3,948 posts Likes: 1 Joined Jan 2007 Location: Chicago, IL More info | Oct 12, 2007 15:50 | #5 Means use a higher apeture. I would use this lens below f/8 but thats me. Paul
WildWolf Goldmember 1,022 posts Likes: 4 Joined Feb 2003 Location: NY More info | Oct 12, 2007 16:55 | #6 it means you will have to use a smaller aperture (higher number Fstop) to get a sharp picture. Using a smaller aperture will cause you to bump up the iso to achieve a faster shutter speed to avoid blurring. Hope this helps 5DMkIV
AirBrontosaurus Goldmember 3,814 posts Likes: 1 Joined Sep 2005 Location: Indianapolis, Indiana More info | Oct 12, 2007 17:46 | #7 Yeah, that isn't exactly a primo portrait lens. It is a relatively "slow" lens, which means it does not let a lot of light into the camera. This means that the shutter speed will be long, which means that if your model moves even a little bit, it will blur the shot. IS (image stabilization) DOES NOT help you here. Chris | My Flickr
Oct 13, 2007 07:16 | #8 wow thanks everyone .. at this rate i'll be getting better sooner than i tought..
Familiaphoto Goldmember 3,948 posts Likes: 1 Joined Jan 2007 Location: Chicago, IL More info | Oct 13, 2007 09:13 | #9 Ah, the 50 f/1.8...the nifty fifty. You just can't go wrong with this lens. Amazing sharpness and color for the price. Paul
Familiaphoto Goldmember 3,948 posts Likes: 1 Joined Jan 2007 Location: Chicago, IL More info | Oct 13, 2007 09:17 | #10 One last piece of advice, you might want to check out the lens forum, great advice on lenses there. Paul
rebel85 Member 56 posts Joined Dec 2006 More info | Paul,
Familiaphoto Goldmember 3,948 posts Likes: 1 Joined Jan 2007 Location: Chicago, IL More info | Oct 13, 2007 09:39 | #12 rebel85 wrote in post #4116183 Paul, In portrait photo, is the 50mm on a crop (30D/40D, etc.) felt equivalent to an 85mm on a full frame (5D/1Ds) or is the disproportionate features still present. In other words, on a crop do you still need to go to the 85mm. I know one rule of thumb is 70-135mm for portrait (which I think referred to 35mm film standards). Just wondered your opinion on this. Thanks. Remember 50mm on a crop is 50mm on a full frame, you are not zooming in more with the crop, you are just seeing less of the image captured by the lens, losing items around the outer edges. If feels like you are zooming more but in reality you are not. As a result, I believe the effect would still be in play. But thats just me, perhaps I am too cautious. Paul
rebel85 Member 56 posts Joined Dec 2006 More info | Thanks Paul; that was my feeling too that a 50mm for portrait no matter the body would cause disproportionate features. Just was curious for others thoughts on the matter.
aznkid.com Member 134 posts Joined Feb 2004 Location: Toronto, Canada More info | Oct 13, 2007 11:10 | #14 Depends on what sort of 'modeling' photography you are doing. I shot these of my girlfriend with my 28-135mm
Might not be the best for portraits, but worked for these 'modeling' shots.
hey every one thanks .. i ended up getiing the 50m /1.8 and wow for the price . I'm more than happy , next is the 85m check out the hotties shot i took.. http://www.phxhotties.com/hin.html
| Latest registered member was a spammer, and banned as such! 2660 guests, 154 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
