I assume this is a sensor for ext flash, anyone know what it is, or know of something similar that works well? Im interested in adding an ext flash to my rig
Oct 12, 2007 15:13 | #1 I assume this is a sensor for ext flash, anyone know what it is, or know of something similar that works well? Im interested in adding an ext flash to my rig IMG NOTICE: [NOT AN IMAGE URL, NOT RENDERED INLINE] Canon R10 , Canon RF 100-400
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Oct 12, 2007 17:35 | #2 Looks like a Vivitar 283 auto-thyristor flash mounted on a standard Vivitar SL-2 slave trigger. You'd need to use your on-camera flash in manual mode with that particular combination, since otherwise the pre-flash would trigger the slave. You'd also need to manually set your camera's aperture to match the range (using the 283's calculator dial ) the 283 was set to. Jon
| Latest registered member is semonsters 1125 guests, 133 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
