On Canons web site they claim that the 40D has a 75 .jpg burst rate.
Mine will only go up to 6. Why is this?
microman23 Senior Member 728 posts Joined Sep 2007 More info | Oct 13, 2007 00:50 | #1 Permanent banOn Canons web site they claim that the 40D has a 75 .jpg burst rate.
YohanPamudji Goldmember 2,994 posts Joined Jun 2007 Location: Mississippi More info | Oct 13, 2007 00:56 | #2 Turn off high ISO noise reduction.
Oct 13, 2007 00:57 | #3 Permanent banWhy would that matter?
cdifoto Don't get pissy with me 34,092 posts Likes: 48 Joined Dec 2005 More info | Oct 13, 2007 00:58 | #4 The website is saying it'll shoot 75 frames before filling the buffer to the point where you must wait for it to clear. That's the buffer depth, not the burst rate. The 6 you're referring to is the Frames Per Second burst rate...the speed at which the shutter and mirror can go through a full cycle. Two completely different specifications. Did you lose Digital Photo Professional (DPP)? Get it here
YohanPamudji Goldmember 2,994 posts Joined Jun 2007 Location: Mississippi More info | Oct 13, 2007 01:01 | #5 microman23 wrote in post #4115240 Why would that matter? Because the high ISO noise reduction takes a while to perform, which means files stay in the buffer longer. So instead of files quickly being moved to the memory card freeing up space for more files, they clog up the buffer while they're being processed.
Oct 13, 2007 01:03 | #6 Permanent banWhat the camera can not decipher between high ISO and low? That makes sense when you are on high ISO, but ISO 100??? common!
YohanPamudji Goldmember 2,994 posts Joined Jun 2007 Location: Mississippi More info | Oct 13, 2007 01:08 | #7 Page 156 of the manual:
Oct 13, 2007 01:13 | #8 Permanent banYohan Pamudji wrote in post #4115277 Page 156 of the manual: "Reduces the noise generated in the image. Although noise reduction is applied at all ISO speeds, it is particularly effective at high ISO speeds. At low ISO speeds, the noise in the shadow areas is further reduced." "! With setting 1, the maximum burst for continuous shooting will greatly decrease." That's just how it is, man. Don't shoot the messenger.
MikeI Goldmember 2,074 posts Likes: 1 Joined Dec 2006 Location: NorCal More info | Oct 13, 2007 06:42 | #9 microman23 wrote in post #4115299 Ahh I see. I did not know it reduced the noise in shadows in low ISO. good deal though. Thanks! This is a feature that you can turn off. Once you do, your buffer should increase. Doubleshot Photography
| Latest registered member was a spammer, and banned as such! 2746 guests, 140 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
