Thread started 13 Oct 2007 (Saturday) 14:37
Mac Mini w/Cinema Display or iMac?
crn3371
Oct 13, 2007 14:37 |  #1
Making the switch to Mac. I'm not a gamer, so I just need something to handle my modest post-processing needs. The mini with a 23" Cinema Display is about the same price as the 20" iMac. I know the spec advantage goes to the iMac, the screen advantage I'm guessing goes to the Cinema Display, especially with the matte/glossy debate on the iMac. So, for you Mac enthusiasts out there, which would you pick, and why?
Tony-S
Oct 13, 2007 14:56 |  #2
I'd go with the Mini and a matte display over the new iMacs. I'm using a 22" Samsung on my Mini and am quite pleased. I'll probably pull the processor in it (1.66 gHz Core Duo) and replace it with the T7600 (2.33 gHz Core 2 Duo) in the next few months. You should also get yourself an external firewire drive with a 3.5" drive in it. I have a 500 gig Seagate FW that I use as my boot drive.
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
philb10
Oct 13, 2007 14:59 |  #3
You don't say what you're going to be running on the mac. I use a mini with a 23" cinema display with Aperture and it's sluggish to say the least.
SWPhotoImaging
Joined Nov 2003
Oct 13, 2007 17:55 |  #4
You need the horsepower and RAM as much as a nice display.
I went with Mac Pro, and will get a big-a$$ display when I can afford it.
SWPhoto-Imaging
Tareq
"I am very lazy, a normal consumer"
Oct 13, 2007 21:06 as a reply to  @ SWPhotoImaging's post |  #5
I decided finally to get MacBook Pro, but later on i will add mini mac with 23" Cinema display, but i will be sure to get powerful mini mac [2.33 or 2.4GHz, 2GB ram or higher if possible].
Galleries:
http://hamrani.deviant​art.com/gallery/ (external link)
Facebook (external link)
Tony-S
Oct 13, 2007 21:11 |  #6
philb10 wrote in post #4117321 (external link)
In what respect is it sluggish? My 1.66 gHz Core Duo does a very decent job, rendering my 30D raw files in 2-3 seconds and PSCS3 is snappy. How much RAM do you have and are you using only the internal drive?
Tony-S
Oct 13, 2007 21:12 |  #7
Tareq wrote in post #4118742 (external link)
Your MBP can drive an external display while closed. You just need to plug in a keyboard and put it aside. Probably won't need a Mini if you have the MBP.
Tareq
Oct 13, 2007 21:15 |  #8
Tony-S wrote in post #4118779 (external link)
Yes i know that, but just for separate work i may prefer to keep my MBP alone, and i can swap the cinema monitor if needed.
Galleries:
philb10
Oct 14, 2007 00:23 |  #9
Tony-S wrote in post #4118768 (external link)
It visibly takes time to render files and I have to wait for it to finish before continuing. I am using the internal drive with 1.5G of ram. From what I have read, aperture is a heavy user of the graphics card and the one in the mini is not really up to the job. However, I knew this when I tried the demo version before buying Aperture. Like many, I'm waiting for the next revision of the Mac Pro to come out before next upgrading.
Tony-S
Oct 14, 2007 09:45 |  #10
My Mini renders raw images in 2-3 seconds, while my MPB does it in about half that time using Aperture. If you're doing a lot of throughput, I can see why a Mini might be a downer. No doubt a Mac Pro would be substantially better and is the way to go if you've got the money to spend. The glossy displays on the new iMacs are a non-starter for me.
crn3371
Oct 14, 2007 12:01 |  #11
Apple still has the white 20" iMacs available as refurbs. How do the original matte iMac displays compare to the Cinema displays?
2,521 views & 0 likes for this thread
Latest registered member is hencc
961 guests, 253 members online
