Is there any difference between this new grip and th older Bg e2?Thanks
Sgt. Senior Member More info | Oct 13, 2007 16:54 | #1 Is there any difference between this new grip and th older Bg e2?Thanks Iain
Sikor7 Senior Member 417 posts Joined Sep 2007 Location: Clearwater, FL More info | Oct 13, 2007 17:06 | #2 The only difference is some weather sealing around the battery compartment. Other than that your BG-E2 is the same grip and is compatible with the 10D, 20D, 30D, and 40D. 40D w grip
LMP Goldmember 1,108 posts Joined Jul 2005 More info | Oct 13, 2007 17:14 | #3 Sikor7 wrote in post #4117830 The only difference is some weather sealing around the battery compartment. Other than that your BG-E2 is the same grip and is compatible with the 10D, 20D, 30D, and 40D. It's not really true weather sealing, more like a strip of felt ..the same material can be found on the 40D's CF card 'door'.
Oct 13, 2007 17:46 | #4 Yea it is like a felt material but it's considered "weather sealing". Mine just came in yesterday and it feels weird. When I shoot vertical its not really comfortable in the hand. It's more square were your thumb wraps around. That's me and i got pretty big hands. I don't know if the bg-e2 is any more comfortable cause i would rather own that instead. Canon 1D III & Canon 5D
MrChad Goldmember 2,815 posts Joined Aug 2004 Location: Chicagoland More info | I own both a 30D/BG-e2 and 40D/BG-e2N. I kaNt sPeL...
Familiaphoto Goldmember 3,948 posts Likes: 1 Joined Jan 2007 Location: Chicago, IL More info | Oct 13, 2007 22:14 | #6 So sad when you compare the BG-E2N to the WiFi grip. The WiFi (sorry can't remember the model number) fits the camera better, is wider and has the AF-On button. Buts its a deal really, only $700 for an AF-On button. Paul
Mark0159 I say stupid things all the time More info | Oct 14, 2007 02:55 | #7 Sikor7 wrote in post #4117830 The only difference is some weather sealing around the battery compartment. Other than that your BG-E2 is the same grip and is compatible with the 10D, 20D, 30D, and 40D. slight correction on this Mark
| Latest registered member is semonsters 922 guests, 118 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
