Thread started 14 Oct 2007 (Sunday) 05:26
IDMK111 DIED today
GyRob
Oct 14, 2007 05:26 |  #1
Well not only does it have focus problems but NOW erro 99 and wont work at all.
I Took the battery out for 45mins and that made no diffrence still wont go -Just tells me to take the battery out and put it back in but after doing that 10 times it gets a bit boreing.
Rob.
"The LensMaster Gimbal"
condyk
Africa's #1 Tour Guide
Oct 14, 2007 05:38 |  #2
That sucks ... bad luck.
https://photography-on-the.net …/showthread.php​?t=1203740
SkipD
Joined Dec 2002
Oct 14, 2007 05:41 |  #3
GyRob wrote in post #4120382 (external link)
Rob.
If the camera has a second (probably disc-shaped) battery like the 20D has, you need to remove that too. The small battery maintains the memory. You have to pull it also to clear memory and effectively "cold-boot" the camera with factory setup. Just pulling the main battery will do nothing of the sort. That's the way it was designed.
Skip Douglas
Pete ­ W
Gallery: 44 photos
Oct 14, 2007 05:43 |  #4
Well I will stick my neck out and guess it is the circuitry to the lens mount pins..... Was on mine... I got the Camera replaced... Good luck on getting it sorted...
All the best
Pete Woods LRPS QGP ASINWP
My Website (external link)
GyRob
Oct 14, 2007 05:49 |  #5
SkipD wrote in post #4120406 (external link)
i will try that .
But it doesent mention that at all on the camera when the warning comes up on the lcd .
Rob.
SkipD
Joined Dec 2002
Oct 14, 2007 05:53 |  #6
GyRob wrote in post #4120422 (external link)
i will try that .
Rob.
I'd bet your book does, though....
Skip Douglas
GyRob
Oct 14, 2007 06:04 |  #7
SkipD wrote in post #4120434 (external link)
it might lol
Well iv tried that and cleaned the contac's still erro 99
Can you imagin taking that tiny screw out to get to the battery so you can reboot the camera while in the field on a cold whindy day .
Rob.
SkipD
Joined Dec 2002
Oct 14, 2007 06:07 |  #8
GyRob wrote in post #4120460 (external link)
it might lol
Rob.
Sounds like your camera needs a trip to the Canon doctor.... Bummer.
You had to remove a screw to get the memory battery out? That's definitely not a field job. Fortunately, you seldom need to take that battery out.
Good luck.
Skip Douglas
GyRob
Oct 14, 2007 06:11 |  #9
SkipD wrote in post #4120473 (external link)
Good luck.
yep a tiny cross head screw good job i have watch menders screw drivers.
So it will go back to Canon again iv only had the darn thing back 2 weeks as it was sent in for a focus problem oh it still has that by the way lol
so they can fix that part too :rolleyes:
Rob.
SkipD
Joined Dec 2002
Oct 14, 2007 06:19 |  #10
GyRob wrote in post #4120482 (external link)
Rob.
Maybe you should ask for a replacement camera this time.....
Skip Douglas
metoyou
Joined Jul 2004
Oct 14, 2007 06:26 as a reply to  @ GyRob's post |  #11
This is only a stab in the dark, but it worked for me, so there is no harm in trying the same.
Remove the battery and back-up battery from your camera.
Now switch the camera to 'on' and depress the shutter button a few times. Yes, I know nothing is happening...well not superficially, but what you are doing is discharging (dumping)
the circuit capacitors, i.e. draining any stored current within the circuits. Leave the camera switched on, go and have a coffee.
Now switch the camera button to off. Replace the back up battery
(with a new one if available, if not use the old battery). Now fit
the main battery and switch on..
This worked for me and the problem has not returned (touch wood!)
I cannot give you any scientific explanation other than what I've mentioned but I can wish you all the best of luck and hope it
does the trick. Please let's know how you went on.
Martin
tinymoon
1 post
Oct 14, 2007 06:41 as a reply to  @ metoyou's post |  #12
I have done everything from remove the back-up battery up to press the shutter button and leave it for almost one hour but it it not working for me.
I sent my damn 1D Mark III as well as all my lens to Canon Service Center for calibration in Zurich-Switerzerland, they said it would be a forgein subject went into the camera and blah blah. I am now waiting for it to come back after 2 weeks.
GyRob
Oct 14, 2007 06:51 |  #13
metoyou wrote in post #4120518 (external link)
Martin
thanks i will try that later when i get back .
Rob.
Riverlander
Oct 14, 2007 07:07 |  #14
Here's another thing to punt on.
With the camera truned off, but the lens in place, press the lens release button (to remove the lens) and twist the lens ever so slightly - a very small angle. Switch the camera on and see if you get an error. I am not sure what goes on here (if it works), but that is a method of overcoming error messages when attaching things like non-focusing tubes and telescope adaptors etc.
Canon; 7D with grip, EF-S 10-22, EF 24-105L, 580EX II flash, 550EX flash, 430EX flash, Sigma; 18-50 f/2.8, 50-150 f/2.8, 120-300 f/2.8, 50-500 f/4.5-6.3 OS, 30 f/1.4, 150 Macro; Sigma APO 1.4x and 2x converters, Benro M-257 tripod & B-1 ballhead. Wimberley Sidekick. Lots of other stuff.http://riverlander.smu​gmug.com/ (external link)
dpastern
Oct 14, 2007 07:43 |  #15
Shouldn't make a difference - the caps will naturally discharge over a period of time without any intervention from the human. I suspect that you had some mechanical issue and depressing the shutter button was enough to fix it.
Dave
edit: Rob - try replacing the round 'coin' battery with a new one, and try discharging the Canon Lithium battery, and then charging it and placing it back in the camera. If that fails, see if you can try another Canon Lithium battery. I take it that you've tried more than one lens ;)
Martin
5,912 views & 0 likes for this thread, 28 members have posted to it.
IDMK111 DIED today
2660 guests, 154 members online
