Thread started 14 Oct 2007 (Sunday) 09:12
ah crap, how do I fix this?
circa
Oct 14, 2007 09:12 |  #1
So I was screwing around with my 30D this morning and I pressed the directional button to the right of my viewfinder, or just under it I should say. Now my camera meter's and focuses to the very centre AF point, how do I fix this?
wonderful skateboard adventures:
http://www.flickr.com/​photos/wjphoto/ (external link)
www.fotophun.blogspot.​com (external link)
bauerman
discount on value meals
Joined Apr 2003
Oct 14, 2007 09:48 |  #2
You want the camera to focus using only the center AF point - this is the generally accepted preferred setting. It sounds like you have stumbled upon better settings to me.
circa
Oct 14, 2007 09:50 |  #3
well I don't want my subject only focussed in the middle of the frame, that makes for a boring composition.
Alan ­ B
Gallery: 45 photos
Joined Dec 2004
Oct 14, 2007 09:50 |  #4
I take it you want ALL the focus points active ?
If you do then all you got to do is press that button again then either turn the control dial on the top of the cam or press in the directional dial on the back of the cam to light up all the points.
If this is not what you want to do then please give some more info.
circa
Oct 14, 2007 09:57 |  #5
that fixed it, thanks Alan.
Alan ­ B
Gallery: 45 photos
Joined Dec 2004
Oct 14, 2007 10:05 as a reply to  @ circa's post |  #6
Ah you want just one lit up, but not the centre.
What i do "in the field" for quickness when shooting a subject.Is press that button, then use the directional control on the back to choose which point i want.Using the dial on the top takes to long.But you have to use the dial if you take a portait shot with the cam on its side using a battery grip.
I'm changing the focus point all the time.
HTH
bauerman
Joined Apr 2003
Oct 14, 2007 10:25 |  #7
circa wrote in post #4121078 (external link)
I was not implying that you wanted boringing-composed center framed shots - but when you let he camera decide what the subject of the photo is by having all the points active - you run the very real risk that something other than your desired subject will be in the crispest focus. I prefer to tell the camera what my subject is.
tzalman
Fatal attraction.
Oct 14, 2007 11:45 |  #8
The idea is to focus using the center point and then, while maintaining that focus by keeping the shutter release half-pressed (or by having set C Fn 4 to 1 and using the * button), to recompose your shot. As well as you controlling the point choice there is also the added advantage that the center point is more accurate than the others.
Elie / אלי
René ­ Damkot
Oct 14, 2007 11:55 |  #9
Off course, when shooting wide open and recomposing a lot, this can be cause for focus errors (external link). Also, if you manually select an AF point, (evaluative)light metering will be biased to that point... (at least it is on the 1D series)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
bauerman
Joined Apr 2003
Oct 14, 2007 12:03 |  #10
tzalman wrote in post #4121545 (external link)
Exactly - well said.
1,072 views & 0 likes for this thread, 5 members have posted to it.
2737 guests, 140 members online
