Could someone help me, what is the best value for the money the Canon 20D or the Canon 350D. I have heard that the 350D feels like a cheap toy and breaks easy is this true?
Also what lens are the best for bird photography?
Thanks!
CanonPhotographer Hatchling 9 posts Joined Sep 2007 Location: New York More info | Oct 15, 2007 16:08 | #1 Could someone help me, what is the best value for the money the Canon 20D or the Canon 350D. I have heard that the 350D feels like a cheap toy and breaks easy is this true? Canon Photographer
asylumxl Goldmember 2,306 posts Likes: 1 Joined Jul 2006 Location: Stuck in an invisible box More info | Oct 15, 2007 16:15 | #2 20D is a better camera and if you can get a good deal on it id go for it, but i wouldnt agree the 350D breaks easily, ive had mine 2 yrs and its still fine. As for which lenses are good for bird photography, Canon 400mm f5.6L is a good lens to start with. ...............
timbop Goldmember More info | Oct 15, 2007 17:14 | #3 At current used prices, the 20D is an absolute steal. It has much better focusing and faster frame rate for birding or other "action" type photography. It is also made of magnesium alloy instead of plastic. For a "birding" only lens the 400/5.6 is a great choice but you will need a tripod ($200) to keep it steady and get the most out of it. For wildlife in general, the 100-400 is a good choice with it's image stabilization (lessening the need for a good tripod). Sigma's 50-500 and 100-300/4 are also good choices, the latter takes a 1.4 TC (multiplier) very well to be an effective 420mm. Those will both need a tripod as well. The canon 300/4 IS also takes a multiplier very well, but can be handheld. Current: 5DM3, 6D, 8mm fish, 24-105/4IS, 35/2IS, 70-200/2.8IS, 85/1.8, 100-400/IS v1, lensbaby composer with edge 80, 580's and AB800's
nwa2 Goldmember 1,131 posts Joined Oct 2006 Location: Manitoba More info | Oct 15, 2007 17:23 | #4 I've not used the 20D, but I have had a 350d for almost 2 years now. The 350d is certainly no toy. It is a very capable camera. My biggest critisisum of it is that the view finder is small and dark. Canon 6D; 7D; 40D:
Clint Senior Member 291 posts Joined Sep 2005 Location: Across the street More info | Oct 15, 2007 18:25 | #5 I just bought my 20D and have had a 350d when it was introduced, each camera is great in its own way but 20D ROCKS, it is a better camera imo A picture is something you draw, A photograph is something you create.
davekadolph "Fix the cigarette lighter" 6,140 posts Gallery: 1 photo Joined Mar 2007 Location: West Michigan--166.33 miles to the Cook County courthouse More info | Oct 15, 2007 18:48 | #6 Light---yes Middle age is when you can finally afford the things that a young man could truly enjoy.
TeeWhy "Monkey's uncle" 10,596 posts Likes: 5 Joined Feb 2006 Location: Pasadena, CA More info | Oct 16, 2007 02:55 | #7 If you check out dpreview and bobatkins site, you'll notice that the image quality is about the same. What the 20D will buy you is features. Some of the features like a better AF and a bigger buffer IIRC, may help you in birding. 20D is bigger and may help to balance your rig if you carry a big lens. Gallery: http://tomyi.smugmug.com/
saab Member 236 posts Joined Sep 2006 Location: Spring Lake, MI More info | Oct 16, 2007 09:03 | #8 I used the 350d for a year and a half before trying out a Nikno D70. I am now ising a 30D (very similar to 20D). "There are no rules for good photographs, there are only good photographs." ~Ansel Adams
LotsToLearn Goldmember 2,290 posts Joined Mar 2007 Location: GTA, Canada More info | Oct 16, 2007 09:28 | #9 Between those two, I'd definitely go 20D. I do prefer the handling and technology wise, the 350 has nothing that is any more impressive. The 400D might have offered more in terms of indecision... for me anyway.
Medic1 Goldmember 1,308 posts Joined Dec 2004 Location: Ontario, Canada More info | Oct 16, 2007 10:14 | #10 I think you also need to take your hand size into consideration. Many people feel the 350D feels awkward due to its size (with larger hand size). That being said, I have a friend who uses the camera and produces excellent images.....but also is looking to move on to at least the 40D if not better.....
Nick_C Goldmember 4,042 posts Joined Jul 2006 Location: Tin Mine Country (Cornwall UK) More info | Oct 16, 2007 10:33 | #11 Image quality wise you would be hard pushed to see any differences I would imagine, I did a direct comparison of a 350D vs 30D & images out of both cameras were identical.
YohanPamudji Goldmember 2,994 posts Joined Jun 2007 Location: Mississippi More info | Oct 16, 2007 10:57 | #12 Spot-on comments here already regarding image quality and build. The 20D and 350D have practically identical image quality, so you're paying for features instead of image quality when you go for the 20D. The 20D has better AF, higher framerate, nicer viewfinder, and is more solid feeling. The 20D also has a PC Sync port for off-camera flash, which doesn't matter to most people--almost never see it mentioned as an important feature for the 20D/30D/40D in comparison with the 350D/400D--but does to me. Subjectively I also find the 20D to be a better size and more comfortable to hold than the 350D--the 350D is too small (even the 20D is still a bit too small for me), and the grip isn't as comfortable as the 20D's--and I also prefer the control layout of the 20D.
Nick_C Goldmember 4,042 posts Joined Jul 2006 Location: Tin Mine Country (Cornwall UK) More info | Oct 16, 2007 12:43 | #13 Yohan Pamudji wrote in post #4134278 Spot-on comments here already regarding image quality and build. The 20D and 350D have practically identical image quality, so you're paying for features instead of image quality when you go for the 20D. The 20D has better AF, higher framerate, nicer viewfinder, and is more solid feeling. The 20D also has a PC Sync port for off-camera flash, which doesn't matter to most people--almost never see it mentioned as an important feature for the 20D/30D/40D in comparison with the 350D/400D--but does to me. Subjectively I also find the 20D to be a better size and more comfortable to hold than the 350D--the 350D is too small (even the 20D is still a bit too small for me), and the grip isn't as comfortable as the 20D's--and I also prefer the control layout of the 20D. The 350D is not a toy. But handling-wise it certainly feels flimsy compared to the 20D, and I personally would never want to use it on a regular basis if I had the option to use a 20D instead. If you have the chance to play with them both, definitely give them a try. Photography is a very subjective experience in terms of what features of a camera will bring you the most enjoyment, so test them out to see if you care about the build quality, etc. You might even prefer the 350D because it's lighter, and not care about the creakiness. Unless you plan to drop the 350D from significant heights, it won't just fall apart on you for no reason. I sure hope people dont go around dropping their cameras from "significant heights"
tsaraleksi Goldmember 1,653 posts Likes: 1 Joined Sep 2006 Location: Greencastle/Lafayette Indiana, USA More info | Oct 16, 2007 12:48 | #14 dave kadolph wrote in post #4130178 And the 20d is 2 models old with no means to confirm shutter count. And the XT is of the same generation, and also has no means to confirm shutter count. Neither camera should be discounted over the other on account of its age. --Alex Editorial Portfolio
montyburnz Mostly Lurking 10 posts Joined Sep 2007 More info | Let's raise the stakes a little bit: Canon 30D vs Rebel XTi (400d)? I currently have a 40D as my main body and was thinking of a good backup body. Should I go XTi or 30D?
| Latest registered member was a spammer, and banned as such! 2924 guests, 169 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
