Thread started 16 Oct 2007 (Tuesday) 06:07
300D problem: Won't turn on! Anyone else?
waterhole
Oct 16, 2007 06:07 |  #1
Hi,
My 300D literally died today - it simply won't turn on! The battery is fine, even tested with a new battery, but no power from the camera at all. It's only two years old and has been working perfectly to date.
I thought I'd try some troubleshooting before sending it in for presumably costly repair. Has anyone else experienced this problem? Any suggestions?
With thanks!
www.cooldeepwater.blog​spot.com (external link)
SkipD
Joined Dec 2002
Oct 16, 2007 06:14 |  #2
Is there a separate memory battery like the 20D has? The one in the 20D is a disc-shaped battery. Its purpose is to maintain the setup memory, time, etc.
Skip Douglas
waterhole
Oct 16, 2007 06:22 |  #3
I hadn't thought to look before, but yes, it has a disc battery.
Hermeto
Oct 16, 2007 06:26 |  #4
waterhole wrote in post #4133111 (external link)
Did you replace that one too?
waterhole
Oct 16, 2007 06:38 |  #5
I only just remembered it was there with SkipD's suggestion. I've taken both batteries out, following advice I just got from another forum, but also discovered that a blown fuse is common with this model too! I had expected to get a bit more life out of a $1500 camera, but apparently 3 years makes it not repair-worthy. Crazy!
number ­ six
fully entitled to be jealous
Oct 16, 2007 12:43 |  #6
Fuse? Didn't know my 300D had a fuse. Do you have any more details?
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
waterhole
Oct 16, 2007 15:06 |  #7
http://forums.dpreview​.com …rum=1031&messag​e=24808193 (external link)
QUOTE: I'd like to share a piece of information: 300Ds occasionally blow the centre power fuse (on the board directly below the mode dial). This happened to one of mine purely through insertion of a dodgy memory card. (the same card went on to trash another camera).
With the fuse blown, everything is dead. Some people have linked across the pads next to the fuse to make the camera usable again (its a tiny surface mount fuse). However you can solder wires onto these pads, lead them just outside the metal cover for this pcb and solder another miniature fuse on (covering it with heatshrink to avoid shorts). I measured the current draw at 100-150 mA, and used a 250 mA fuse. This has worked fine with a variety of lenses. I have further details (where to get the fuses etc) if anyone else is in the same boat.
number ­ six
Oct 16, 2007 15:10 |  #8
Thanks! I don't have a problem at the moment, but it's good to be prepared...
-js
"Be seeing you."
1,342 views & 0 likes for this thread, 4 members have posted to it.
2660 guests, 154 members online
