Thread started 16 Oct 2007 (Tuesday) 17:05
Mark2n - RAW backing up to SD Card
WAF
Oct 16, 2007 17:05 |  #1
I will be shooting a college football game soon. I can easily see shooting 1,200 to 2,000 shots. I realize this means I will need to change out to a new CF card at least once. I am trying to get my CF and SD card paired up as close as possible. I am using an 8gig CF card (shooting RAW) and backing up to a 2gig SD card set at M1. Questions:
1) Do I need a bigger SD card for a closer match? If so, what size?
2) If the SD card fills up does it keep the M2N from firing?
3) What do you pros/semi-pros do? How would you handle the card situation?
Thanks. AF:D
Adrian ~ Canon 30D, Canon Mark3, Canon 5D MarkII, Canon 5D MarkIII, Canon 7D, Canon:70-200mm/f2.8, 85mm/1.2, 50mm/1.4, Canon 14mm Fisheye, Canon 16-35mm f2.8L, Canon 24-70mm f/2.8, USM, 1.4X, 2.0X , Quantum T5d-R flashes.http://www.adrianfreem​an.com (external link)
gromeo
Oct 16, 2007 21:12 |  #2
I use 1 and 2 gig cards, on JPEG Large, shooting RAW for me is just takes to much time, I usually D/L at half time, edit, caption and transmit 4-5 pics all in 15-20 mins. Never have used SD cards.
Nikon D4 and 60 2.8D Micro, 24-70 2.8G, 70-200 2.8G VRII, 200-400 VRII, SB800, SB600, Pocket Wizards, 4x WL-1600, Quantum Turbo 2x2, Sekonic 358 meter, TT AS, Takeoff, Belt System
http://rguzmanphoto.ph​otoshelter.com/ (external link)
http://www.romeoguzman​photography.com (external link)
http://www.sportsshoot​er.com/rguzman (external link)
tsaraleksi
Oct 16, 2007 21:16 |  #3
I just shoot to the SD too, like I would the CF. I guess I probably should be backing up. I do for a lot of other shoots.
--Alex Editorial Portfolio (external link)
|| Elan 7ne+BG ||5D mk. II ||1D mk. II N || EF 17-40 F4L ||EF 24-70 F2.8L||EF 35 1.4L || EF 85 1.2L ||EF 70-200 2.8L|| EF 300 4L IS[on loan]| |Speedlite 580EX || Nikon Coolscan IV ED||
vetkrazy
Oct 17, 2007 21:52 |  #4
I normally use of 4gb CF and a 2gb SD. Shoot on the CF and only go to the SD if my CF fills and I don't have time to change. The only time I use both cards is when I have a tight deadline, then I use the SD for jpeg's because I can make a quick edit and then send them to the paper. Other than that I shoot 100% raw.
Wrap your ass in fiberglass.... You're only young once but you can be immature the rest of your life
http://vetkrazy.exposu​remanager.com/ (external link)
jordan101
Oct 18, 2007 17:52 |  #5
i only shhot SD cards and i use 2 and 4 Gb cards- large jpeg
tsaraleksi
Oct 18, 2007 18:06 |  #6
jordan101 wrote in post #4149722 (external link)
How exactly do you do that with your XT?
BTW this thread refers to the capability of the 1Dm2 and newer cameras to shoot to both a CF and SD card.
1,126 views & 0 likes for this thread, 5 members have posted to it.
1502 guests, 130 members online
