Thread started 17 Oct 2007 (Wednesday) 11:13
Why is my MK II doing this?
metalman1010
Oct 17, 2007 11:13 |  #1
So I have erased, formatted and re-erased my CF card (4GB) Ultra IV card and the reading on the top still says I only have about 200 photos left before the folder is filled. I re-inserted the card into my computer and dumped all files into the trash. I then stuck the card back into the camera and had the card reformatted.
The 100 folder is completely empty. I have checked this on both the camera and the computer.
I am set on JPEG L, not raw.
The other thing is when I take a burst of photos and then erase them the top reading still says the same amount of photos that I would of had after taking the initial shots.
example I started with 225 took 10 shots and after erasing those shots it still shows I only have 215 left before the card is full.
I have taken the battery out and let the camera sit for about 5min and that didn't work.
I have a shoot tonight and I won't be able to achieve what I need in just 200 shots.
Anyone have this happen to them?
Ross
http://crossczech.smug​mug.com (external link)
Unfortunatly IM now all Nikon...;)
If you can do it, I can do it. I just have to figure out a different way to do it.
rowdyred94
Oct 17, 2007 12:26 |  #2
What does the capacity show on the computer (right-click, 'properties' in Windows)? Have you tried formatting it there? I format in the computer so I can assign name to my cards, and never format in the camera. I delete the numbered folders each time I download the photos.
~ Clint :: Galleries (external link) ::
René ­ Damkot
Oct 17, 2007 12:41 |  #3
Reset the camera counter: It's probabely at 9800 or so.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
metalman1010
Oct 17, 2007 14:18 as a reply to  @ René Damkot's post |  #4
How do you reset the camera counter, I thought you couldn't do that?
And the other thing is Im using a Mac and I have deleted all the files on the computer that were in the card.
Ross
Tapeman
Sliced Bread
Joined Jan 2004
Oct 17, 2007 15:32 |  #5
When you get to 10,000 it will be back to normal
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
motion_projekt
Oct 17, 2007 15:36 |  #6
metalman1010 wrote in post #4141718 (external link)
Ross
use the disk utility and erase the disk image on the card. Or you could control-click and format the disk. Either way is fine.
EOS 5Dmk3x2 | 24L | 50L | 135L
Instagram (external link) | Gear | SportsShooter (external link) | Portfolio (external link) | Blog (external link)
René ­ Damkot
Oct 17, 2007 16:36 |  #7
File counter, not shutter count ;)
Menu > middle menu (yellow 1) > File Numbering > M-Reset
Not sure what (the relevance is of) you're saying here...
Mr. ­ Clean
Oct 17, 2007 20:44 |  #8
Ya, sounds like you have the 9999-10,000 images issue. Either manually reset the image counter or put that bastard on high speed burst and rap off 200 small jpegs of your favorite wall :D
Mike
some shots @ Zenfolio (external link)
895 views & 0 likes for this thread, 6 members have posted to it.
2666 guests, 154 members online
