Thread started 18 Oct 2007 (Thursday) 08:02
When to use MLU?
jacobsen1
Oct 18, 2007 08:02 |  #1
When should we be using MLU? Anytime the camera is on a tripod? Anytime I'm using a release? Anytime the shutter speed is less than a certain point?
I know what it is, I'm just not sure when I should be using it. Personally I've been using it anytime I'm on a tripod. With the 5D I turn it on and set the drive to "timer". This defaults to a 2 second timer and handles the MLU for me, so I figure why not. When I use a remote I tend to get impatient and press it twice fast to get the shot...
Also if/when using MLU how long should I wait before taking the picture if doing it manually? I figure if the camera defaults to the 2 second timer, that's what canon recommends so why not right?
My Gear List
my sites:
benjacobsenphoto.com (external link) | newschoolofphotography​.com (external link)
GND buyers FAQ
FOR SALE: 5Dii RRS L-bracket, 430II, 12mm macro tube PM ME!
jacobsen1
Oct 18, 2007 08:12 |  #2
Oh, and if anyone from Canon ever sees this, can we PLEASE HAVE A BUTTON ON THE CAMERA THAT DOES THIS?!!! Has anyone here ever used that stupid direct print button? Make that the MLU shortcut please!!! Or at the very least give us the option to set what it does like you do with the set button...
My Gear List
my sites:
GND buyers FAQ
gjl711
Oct 18, 2007 08:21 |  #3
MLU is most effective when the camera is tripod mounted, shutter speeds are slower than 1/125th or 1/60th of a second but not more than a few seconds. Shutter speeds faster than that and the shutter will have completed it’s task before any vibration has a chance to affect the pics and for shutter speeds much longer than a few seconds the vibration will not notably affect the pic either.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Cobra351
Joined Sep 2003
Oct 18, 2007 08:22 as a reply to  @ jacobsen1's post |  #4
Not sure what the proper response to this is, but I'll comment on what I do. Like you mentioned, I tend to use it whenever I'm shooting from the tripod. It's likely not required as sometimes the shutter speed is higher, but it's a habit for me now I guess. I used to use it below certain shutter speeds with certain focal lenghts, but again now I pretty much use it all the time (from the tripod).
As to the delay when using a release, well, not sure about that either, but I try to do a four or five count after flipping the mirror up until I take the shot (unless the shutter speed is going to be real slow, then I wait a bit longer to make sure there's no vibration). Again, I'm not sure what the "correct" method is, but I no longer have any blur/focus issues since doing things like this. I hope this helps? Sorry I can't be more technical or exacting in the response!
Canon 5D Mark II
Canon 40D - Infrared Modified (www.lifepixel.com (external link))
Canon Lenses: 17-40, 24-105 f/4 IS, 100 2.8 IS Macro, TS-E 90, 70-200 f/4 IS, 100-400 IS
Canon EF25 II , EF 1.4x II
Smith & Wesson M&P 340CT .357 Magnum
bob-e
Oct 18, 2007 09:12 |  #5
I'd like to see 100% crops with and without MLU and if I'm convinced, I still won't use it. :)
Fitty Dee, 30D, 17-55 2.8 IS, Σ 10mm 2.8 FE, Σ 30mm 1.4, Canon 50mm 1.8, Canon 100 2.8 Macro, 70-200 F4L, 430EX
gjl711
Oct 18, 2007 09:17 |  #6
Cobra351 wrote in post #4146514 (external link)
...As to the delay when using a release, well, not sure about that either, but I try to do a four or five count after flipping the mirror up until I take the shot (unless the shutter speed is going to be real slow, then I wait a bit longer to make sure there's no vibration). Again, I'm not sure what the "correct" method is, but I no longer have any blur/focus issues since doing things like this. I hope this helps? Sorry I can't be more technical or exacting in the response!
You might try setting the delay timer along with MLU. The delay timer cuts down to 2 seconds than automatically fires the shutter. It makes the feature pretty easy to use.
  • Set MLU enabled
  • Set auto timer
  • Compose, focus, and press the shutter
  • Mirror pops up then 2 seconds later the shutter fires.
It gets rid of one manual step having to fire the shutter after the MLU occurs.
::Gear::
Tapeman
Sliced Bread
Joined Jan 2004
Oct 18, 2007 09:32 |  #7
It helps most in approximately the 1/30th to 2 second range.
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
jacobsen1
Oct 18, 2007 09:46 |  #8
Why doesn't it help on longer exposures? Like longer than 2 seconds.
My Gear List
my sites:
GND buyers FAQ
rowdyred94
Oct 18, 2007 10:00 |  #9
Because the vibration period is such a small portion of the overall exposure that it is effectively overwritten. It's like if someone walked past your lens on a 30 sec. exposure. You'd likely not even see it unless they were wearing bright red.
~ Clint :: Galleries (external link) ::
jacobsen1
Oct 18, 2007 10:09 |  #10
What does it hurt though? I guess it's just a waste of 2 seconds...
Agreed on the people disappearing. I love how things magically disappear on long exposures...
My Gear List
my sites:
GND buyers FAQ
JackProton
Oct 18, 2007 11:51 |  #11
I tend to use MLU with a tripod and longer lenses regardless of the exposure time. A very short exposure might avoid blurring from mirror slap but I wouldn't count on it working 100% of the time.
JohnJ80
Oct 18, 2007 12:04 |  #12
JackProton wrote in post #4147627 (external link)
Correct. There are high frequency components to the mirror vibration. See:
http://markins.com/cha​rlie/report4e6.pdf (external link)
I agree that it would be huge great if Canon provided a button on the camera that could be programmed to toggle MLU on and off.
J.
Obsessive Gear List
"It isn't what you don't know that gets you in trouble; it's what you know for sure that isn't so." - Mark Twain
Mr. ­ Clean
Oct 18, 2007 12:10 |  #13
Tapeman wrote in post #4146854 (external link)
And at longer focal lengths.
Mike
some shots @ Zenfolio (external link)
vpnd
Oct 18, 2007 12:17 as a reply to  @ Mr. Clean's post |  #14
deffinately on longer focal lengths
Canon "Snappy".... Thanks Mom and Dad!
"I don't like to play dress up, or pet my gear. I like to shoot stuff and then print it and put it on my wall."
jacobsen1
Oct 18, 2007 12:30 |  #15
How does it help on longer focal lengths? Do they just magnify the vibration more?
My Gear List
my sites:
GND buyers FAQ
3,012 views & 0 likes for this thread, 17 members have posted to it.
When to use MLU?
2747 guests, 154 members online
