Thread started 18 Oct 2007 (Thursday) 10:35
IR Shutter Trigger
GBRandy
Oct 18, 2007 10:35 |  #1
I am looking for an IR trigger for my IIn.
What I want is a light beam that activates the shutter release when the beam is broken...ie: if a bird flies though it, a ball drops though it, etc.
I seem to recall Canon having an Infra Red (IR) device but can not find it....anyone know if there is an aftermarket tool for this?
Thanks!
GBRandy
GearList | Nikon 1977 - 2007 |
JackProton
Oct 18, 2007 11:46 |  #2
The Canon IR remote, at least for my 400D, is only a remote shutter/timer release and won't function as a proximity trigger. I'm not aware of any commercial products - that is something that you'll need to build yourself though you might be abale to find a DIY kit. This is actually quite a common project for people interested in high-speed photography and there are various circuit plans available on the web for this and similar projects. If you know your way around a schematic and can handle a soldering iron, its not very complicated.
You might be able to start with something simple like this pre-constructed controller - http://makezine.com/fl​ashkit/ (external link) - and just wire it to whatever connector the 1D uses for its remote shutter release (or wire it into a cheap ebay remote shutter release).
GBRandy
Oct 19, 2007 10:38 |  #3
Well Nikon Makes an ML-3 IR Cable release that does what i want....so, does Canon? I can't find it...legacy stuff perhaps?
See here:
http://www.nikonusa.co​m …t=1&grp=56&prod​uctNr=4645 (external link)
GBRandy
NickR
Gallery: 28 photos
Oct 19, 2007 10:51 |  #4
GB, This may be over the top but I think it can what you are after.
ZIGVIEW S2
Live Preview Viewfinder - Convenient real time display of the viewfinder image on the Zigview S2’s 2.5 inch, tilting and rotating TFT LCD display.
TV Output – Take a video feed directly from the Zigview S2 to display on an external monitor or TV, or directly to a Video or DVD recorder.
Detachable Screen – The TFT LCD screen can be detached from the main unit and used in conjunction with accessory cables up to 10 metres from your camera with a shutter release function.
Motion Sensor - Triggers the cameras shutter where motion is detected through the lens.
Interval Timer – Can be set up to trigger the shutter using a variety of sophisticated settings.
Cable Release – Acts as cable release when Zigview S2 is used in conjunction with the remote screen accessory cables.
Bulb Exposure – Accurate Bulb Exposure facility. Can be used in conjunction with the interval timer
* Download PDF brochure (1MB)
Cheers
Nick, UK
JackProton
Oct 19, 2007 14:44 |  #5
GBRandy wrote in post #4153964 (external link)
See here:
It might not be too hard to actually modify the Nikon unit to work with Canon. I'd think all you would need to do is to replace the shutter release connector with a Canon type. Simple mod really.
GBRandy
Oct 19, 2007 15:19 |  #6
JackProton wrote in post #4155320 (external link)
I was wondering just how I might do that......I guess i can buy one and take it apart see where it leads me :)
So far I have Nikon Lens caps ('cuz the canon ones stink) I have an SB 24 I can fire via IR from the Canon...and now a Nikon IR trigger...hummmm kinda weird.
Soon it will turn onto this!
GBRandy
NickR
Gallery: 28 photos
Oct 19, 2007 15:50 |  #7
GBRandy wrote in post #4155486 (external link)
GB, That's funny I was thinking that 5 minutes ago, now I'm going to trawl the web for Nikon lens caps to fit my 70-200 and 16-35:D
Cheers
Nick, UK
JackProton
Oct 19, 2007 17:11 |  #8
Heh, heh - Francankon1D. "Grrrrr, water BAD!"
Yeah, you should only need to snip the end off of the cable and use a meter to figure out which wire is the shutter release relay contacts then graft on a compatible Canon type connector. You might need to pick up a cheap Chinese 1D wired shutter release on ebay for the connector.
2,574 views & 0 likes for this thread, 3 members have posted to it.
IR Shutter Trigger
2747 guests, 154 members online
