Thread started 18 Oct 2007 (Thursday) 14:21
Best SLR for sports?
Frizholy
Oct 18, 2007 14:21 |  #1
Right now I have a rebel xt with a 70-200 f4 IS telephoto lens and it seems a bit slow and not that great of quality. Which body would be the best upgrade if I want more fps and all around better camera for sports?
heres some examples of what the xt can do
IMAGE: http://farm2.static.flickr.com/1189/1410214922_72daaf5e82.jpg
IMAGE: http://farm3.static.flickr.com/2262/1620831572_41bac4c817_o.jpg
IMAGE: http://farm3.static.flickr.com/2203/1607050158_774ca78687.jpg
www.SeanFrisoli.com (external link)
Art Center College of Design
mclaren
Oct 18, 2007 14:24 |  #2
sports cam - EOS 1D mkIII and some L glass such as 70-200 2.8, 300 2.8, 400 2.8
Nikon (yes) D50 w 18-55, sigma 70-300 apo.
Canon 1D mkIII, 40D, 5D.
Canon 70-200 2.8L, Canon 100-400L, Canon 24-70, Canon 85 1.2.
Frizholy
Oct 18, 2007 14:32 |  #3
mclaren wrote in post #4148531 (external link)
let me verify that it has to be below a mark :D I have a budget under $2000 for a body
btw i shoot alot of paintball too if that helps.
mknawabi
Oct 18, 2007 14:33 |  #4
Then a 40D with a 70-200 f/4L IS would work best for you. Unless you would want the 2.8/2.8IS. If you want to save even more money, go with a 30D.
tonylong
...winded
Gallery: 60 photos
Oct 18, 2007 14:36 |  #5
Frizholy wrote in post #4148515 (external link)
Right now I have a rebel xt with a 70-300 f4 IS telephoto lens and it seems a bit slow and not that great of quality. Which body would be the best upgrade if I want more fps and all around better camera for sports?
Frizholy,
When you ask a question like this, it might help if you let us know what your price range is!
The Rebel line is the entry level line of Canon DSLRs. There are several models/classes that have better performance at significantly higher price points!
If price is no object, follow the suggestion above for the 1D MkIII with at least the 70-200 f/2.8L lense (I would use that lens no matter what body you have for sports). It is the fastest camera out there, which makes it great for sports.
The new 40D is a much more affordable "prosumer" body that features 6.5 frames-per-second, which many in these forums are using for sports, because it's the fastest prosumer camera available. So, if you have a spending limit of less than $5000 USD, the 40D and the 70-200 f/2.8L lens would be a great combination. Your f/4 lens will tend to be too slow to get sharp action shots.
Hope this helps,
Tony
Several Canon cameras, too many lenses and stuff to list :)
If you want to see pics from a recent day trip to Mount St. Helens, an active volcano in Washington State, with a 5D, click here (external link)
Tony
Frizholy
Oct 18, 2007 14:40 |  #6
tonylong wrote in post #4148607 (external link)
Frizholy,
Hope this helps,
Tony
that clears it up alot actually. I am going to try to trade or sell my f4 for a 2n8 now;)
basroil
Oct 18, 2007 15:03 |  #7
Frizholy wrote in post #4148622 (external link)
f4 vs f2.8 for outdoor daytime sports is a null issue. i use my f2.8 lens @f4 most of the time when it's bright and sunny, since it's sharper at f4 than f2.8. only place f2.8 will help a lot is with indoor and nighttime sports.
JasonSTL739
Oct 18, 2007 15:09 |  #8
Another vote for the 40D given your budget - forget the 30D, 40D's AF especially with servo mode seems to be quite improved. No way I'd bother with the older body.
http://www.sedura.com (external link)
tonylong
...winded
Gallery: 60 photos
Oct 18, 2007 15:12 |  #9
basroil wrote in post #4148759 (external link)
I agree about stepping an f/2.8 up -- it's pretty characteristic for lenses to be less sharp wide open -- but the same would be true of an f/4 lens. And the 70-300 he has, if it's the one I used initially is pretty soft and if not in great light just doesn't cut it speed-wise. Going to a better and faster lens for what he's doing should be a no-brainer. IMHO:)!
Tony
Tony
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Oct 18, 2007 15:13 |  #10
It's a 1D for sports.
The question is budget, and if used is o-kay.
The 1D Mark II (2) used will cost less than half of a new Mark 3
@ 8MP and excelent AF and burst rates it remains one of the best sports camera made.
If megapixels are not of a huge concern, and you don't intend to print larger than 8x11 often, then even a 1D "classic" @ 4.5 MP would be near perfect.
You sacrifice only some features, a shorter battery life (much shorter) more noise in darker situation's with higher ISO settings, and those megapixels and little else.
CDS' HOT LINKS
In2Photos
Oct 18, 2007 15:14 |  #11
tonylong wrote in post #4148807 (external link)
Tony
I believe he has the f/4 L, not the consumer 70-300 IS version. The F/4 is sharp wide open and on the XT is not a bad combo. The 40D would only make it that much better (and a combo I hope to have in the near future).
Current Gear and Feedback
dschach
Oct 18, 2007 15:56 |  #12
Before you spend money on the 40D, which is a great sports camera, you can get better pictures with your rebel XT by changaing your technique. Two problems I see with your photos are that you are shooting from the wrong spot and your white balance is off.
Try standing next to the goal and shoot towards the plays as they run towards you. That way you'll get some faces in the shots. The colors look too blue. I suspect you are shooting with auto white balance. Try setting it to daylight or cloudy or a custom white balance. I personally prefer cloudy (even on sunny days) as it gives the photos more warmth.
pjtemplin
Oct 18, 2007 15:58 |  #13
What's wrong with the pictures you're getting now? What was the EXIF data on the pictures you've shown us?
If you need a faster shutter speed to stop the action, you need a higher ISO. If the XT won't give you low-noise performance that meets your desires at the ISO settings you'd need, you can fix that with aperture or better body.
If you need better focus performance, you need a better body. See others' posts for choices, tradeoffs, and the like.
If you desire the ability to take a second picture more quickly after a first picture, you either need to upgrade your trigger finger (if in single-exposure drive mode) and/or select a camera with a higher frame rate. 3fps means one picture every 333ms. 4fps is one per 250ms, a savings of 83ms. 5fps saves another 50ms, 6.5 saves another 46ms, 8.5 saves another 37ms, and 10fps saves a not-so-whopping 18ms. Keep in mind that (I think) Canon quotes frame rates with shutter speeds of 1/250th or faster (i.e. no more than 4ms shutter time).
1D MkIII, 24-105 f4L IS, 70-200 f2.8L IS, nifty fifty, 3xSpeedlite 580EX II, Rebel XTi w/ kit 18-55mm
basroil
Oct 18, 2007 16:33 |  #14
bottom line, mkiii is the best, followed closely by mkii(n), then 40d. reason? battery. not only is the 1d battery bigger (mkiii's lasts for about 4000 shots with a bit of IS and a snudge of chimping), but it also has a bigger draw. that means you can use both servo and IS at the same time (i really hope you where not doing that with an XT...). although the 40d has a great af for it's price, the battery draw is the same as the xt's
Frizholy
Oct 18, 2007 17:06 |  #15
dschach wrote in post #4149098 (external link)
you mean like this?:rolleyes::D
IMAGE: http://farm3.static.flickr.com/2331/1606161059_637fb17d77.jpg
IMAGE: http://farm3.static.flickr.com/2029/1606160681_db178d0fea.jpg
but to everyone whos posted, thanks for the help! Keep in mind that I have no problem buying a used camera at all! Im looking at the 40d which looks very sufficent and to have a mark would be amazing too. the only thing is, i dont know which mark to look at so Id still need to learn about the different types of marks.
Edit: does anyone mind posting links to where i can find a nice mark cheap or maybe even a 40d? as long as they are in good condition it does not matter who used it before me
4,198 views & 0 likes for this thread, 17 members have posted to it.
2743 guests, 154 members online
