I hate having to go into a menu to set ISO.
M.Wheeler Member 37 posts Joined Sep 2007 More info | Oct 18, 2007 15:07 | #1 I hate having to go into a menu to set ISO.
numbersix fully entitled to be jealous 8,964 posts Likes: 109 Joined May 2007 Location: SF Bay Area More info | Oct 18, 2007 15:16 | #2 ISO priority? If that's the same sort of thing as aperture priority, as an example, it gets set and other exposure values are selected by the camera for correct exposure. "Be seeing you."
In2Photos Cream of the Crop 19,813 posts Likes: 6 Joined Dec 2005 Location: Near Charlotte, NC. More info | Nikon cameras have it and it supposedly works well. The 40D has a version of it but it lacks full functionality. Mike, The Keeper of the Archive
mrkgoo Goldmember 2,289 posts Joined Aug 2006 More info | Oct 18, 2007 15:25 | #4 Isn't P mode essentially iso priority?
In2Photos Cream of the Crop 19,813 posts Likes: 6 Joined Dec 2005 Location: Near Charlotte, NC. More info | ISO priority isn't just adjusting the ISO. In ISO priority the ISO is actuall NOT the priority. It is like M mode with ISO being chosen by the camera rather than the user. Mike, The Keeper of the Archive
Woolburr Rest in peace old friend. 66,487 posts Gallery: 115 photos Best ofs: 2 Likes: 143 Joined Sep 2005 Location: The Tupperware capitol of eastern Oregon...Leicester, NC! More info | Oct 18, 2007 15:40 | #6 It appears that some folks are a bit confused about what ISO priority is...you manually set the shutter speed and the aperture...and the camera then adjusts the ISO setting to give you the proper exposure. People that know me call me Dan
pjtemplin Senior Member 311 posts Joined Aug 2007 More info | Oct 18, 2007 15:51 | #7 Permanent banIt appears that some folks are a bit confused about what ISO priority is...you manually set the shutter speed and the aperture...and the camera then adjusts the ISO setting to give you the proper exposure. Where'd you find that defined? Or is that just someone's idea of "I'll make up my own term" to suit what I want? What you appear to be talking about would be along the lines of Aperture/Shutter Priority. Let the operator set the Aperture and Shutter, and let the camera choose the ISO. Program would be ISO priority (setting ISO was more important than setting anything else). 1D MkIII, 24-105 f4L IS, 70-200 f2.8L IS, nifty fifty, 3xSpeedlite 580EX II, Rebel XTi w/ kit 18-55mm
In2Photos Cream of the Crop 19,813 posts Likes: 6 Joined Dec 2005 Location: Near Charlotte, NC. More info | Oct 18, 2007 15:53 | #8 pjtemplin wrote in post #4149053 Where'd you find that defined? Or is that just someone's idea of "I'll make up my own term" to suit what I want? What you appear to be talking about would be along the lines of Aperture/Shutter Priority. Let the operator set the Aperture and Shutter, and let the camera choose the ISO. Program would be ISO priority (setting ISO was more important than setting anything else). And yes, the 1Dmk3 has it, but it takes a few steps to get it. First, put the camera in Manual mode and choose the Aperture/Shutter values you want. Second, enable the custom function for ISO Safety Shift. Done. Nikon has had the term for quite some time as Dan mentioned. Mike, The Keeper of the Archive
CyberDyneSystems Admin (type T-2000) More info | Oct 18, 2007 15:56 | #9 Woolburr wrote in post #4148989 It appears that some folks are a bit confused about what ISO priority is...you manually set the shutter speed and the aperture...and the camera then adjusts the ISO setting to give you the proper exposure. Much like in Aperture priority or Av....you manually set the ISO and aperture...and the camera adjusts the shutter speed to give you the proper exposure. Read that again, it doesn't make sense! GEAR LIST
numbersix fully entitled to be jealous 8,964 posts Likes: 109 Joined May 2007 Location: SF Bay Area More info | Oct 18, 2007 16:07 | #10 Woolburr wrote in post #4148989 It appears that some folks are a bit confused about what ISO priority is...you manually set the shutter speed and the aperture...and the camera then adjusts the ISO setting to give you the proper exposure. Much like in Aperture priority or Av....you manually set the ISO and aperture...and the camera adjusts the shutter speed to give you the proper exposure.
"Be seeing you."
Andrushka "all warm and fuzzy" 3,735 posts Likes: 12 Joined Oct 2007 Location: OC, CA More info | Oct 18, 2007 16:32 | #11 Permanentlyman, ISO was the first and easiest thing for me to figure out on my DSLR... typically wouldnt a particular ISO setting will work for a given setting, you know like say a portrait or maybe a landscape, ok then when you are done with one thing you pack up and move on to something else, unless you are walking in and out of a building or something like that... if you have to reset your ISO twice in a shoot, i guess that doesnt seem so bad - its not like you have to reset every shot right? http://www.paradigmphotographyoc.com
racingsafetyman Member 220 posts Joined Jul 2006 Location: Northants, UK More info | Oct 18, 2007 16:33 | #12 M.Wheeler wrote in post #4148785 I hate having to go into a menu to set ISO. Buy a 40D then and you don't have to go into a menu, just press one button and spin the dial! Colin
mrkgoo Goldmember 2,289 posts Joined Aug 2006 More info | Oct 18, 2007 16:46 | #13 number six wrote in post #4149166 Some folks (me) are confused by your reasoning. You seem to be defining ISO priority so it's exactly opposite to the standard definitions of aperture or shutter priority. With aperture priority, you set the aperture and it does not change. Same for shutter priority. Now go back and read my previous post. We already have ISO priority as the camera's only mode: set it and it does not change. Am I still confused? ![]() -js Ya/
Collin85 Cream of the Crop 8,164 posts Joined Jan 2007 Location: Sydney/Beijing More info | Oct 18, 2007 16:57 | #14 Hmm, I personally find it surprising most people didn't get what the OP meant. He's talking about 'Auto-ISO'.. or whatever the heck you wanna call it. Basically like what Dan said. number six wrote in post #4148829 You don't say what camera you're using, but even my ancient 300D has ISO settings available via a button and wheel on the camera, no menus involved. That's a menu! Col | Flickr
Mikhaily Junior Member 29 posts Joined Jun 2007 More info | Its not a Canon but the Pentax K10D offers ISO priority [along with other 'odd' modes]. Work just like Av or Tv mode, where you select the iso with the dial, camera selects aperture and shutterspeed. [2217*]
| Latest registered member is NekoZ8 1306 guests, 105 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
