Thread started 07 Aug 2004 (Saturday) 15:07
Getting the shot....
Andy_T
Joined Jan 2003
Aug 07, 2004 15:07 |  #1
Hi,
I somehow admire that guy ...
IMAGE: http://gallery.photo.net/photo/2591579-lg.jpg
Changing of guards at Royal palace, Seoul
What do you think about the photo?
Best regards,
Andy
some cameras, some lenses,
and still a lot of things to learn...
(so post processing examples on my images are welcome :D)
If you like the forum, vote for it where it really counts!
CLICK here for the EOS FAQ
CLICK here for the Post Processing FAQ
CLICK here to understand a bit more about BOKEH
rick ­ barclay
Joined Jan 2004
Aug 07, 2004 18:00 |  #2
Great subject matter, and a great idea for a picture.
What I don't like is the washed-out look of the guard's uniforms and the
hazy look of the entire image. I would have played around a lot with the
colors here and tried to sharpen it a bit.
With a little adjustment, I'd say it's a keeper for sure.
You are cordially invited... (external link)
Andy_T
Joined Jan 2003
Aug 08, 2004 13:53 |  #3
Rick,
thanks for the feedback!
Unfortunately, the sharpening is as much as I could get. I sharpened the picture with USM, and anything more gets grainy. I already had to apply a gaussian blur to the wall, because it really showed there.
Reason is that it is basically a 100% crop from a larger G2 picture.
I'll try to bump the colour a bit
Best regards,
Andy
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Aug 08, 2004 15:03 |  #4
The problem that I see is the color cast. Too blue.
Do you have PS Elements 2.0? It has a "Color Cast" correction feature that is mysteriously absent from PS 7 and CE. You just eye-drop an area that is "supposed" to be white (or black or grey) - in this case the guys shirt - and it automatically adjusts the color temp of the shot so that the area IS white.
This feature alone makes PSE2 worth buying - even if you are using "more advanced" programs.
After adjusting the color cast, then nudge the saturation just a hair.
Rad
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
Andy_T
Joined Jan 2003
Aug 08, 2004 16:16 |  #5
Rad,
thanks for the suggestion, I'll try that.
As my luck would have it, I only have Elements 2.0 ?!
Best regards,
Andy
Don ­ Ellis
Joined Sep 2001
Aug 12, 2004 20:40 |  #6
Andythaler wrote:
Rad,
Best regards,
Andy
Hi Andy,
Interesting, exotic photo... I think most of your color problems will disappear by setting a black point, which you should be able to do in either Curves or Levels (your choice, same thing for this purpose).
The nearest-to-black point I can find in this photo is on the middle guard's right boot (his right), at the very top of the boot in the middle of his leg. Click on your black eyedropper and then click that point and see what you think.
Cheers,
Don
1,801 views & 0 likes for this thread, 4 members have posted to it.
1506 guests, 130 members online
