Thread started 20 Oct 2007 (Saturday) 18:43
40D Dust and the role of Auto-levels to survey it
Box ­ Brownie
Oct 20, 2007 18:43 |  #1
Hi All
It was only in the past few days I have had nice blue skies to get soem decent dust check images and would offer the following observation.
Previously with grey/cloudy skies even defocused I was seeing sensor marks (dust or whatever) that a rocket blower would not shift Note this was using Auto levels to 'reveal' the dust and its locations. The dust was even showing up at f9
Well, now to the point of this post. I took a series of sky images at all apertures down to F32.
From f16 I could make out a couple dust spots when the image was viewed at 100% then count increased only slightly at f32 but with auto levels the whole bunch of a couple of dozen appeared. I think at f9 I could just about make out one when viewed at 100%.
So, do we ever use auto levels in normal PPing (I never have done that). And how often do we use a crop taken 'out' when zoomed at 100%. In other words for most folk I surmise dust should not be an issue and for the odd spot that appears over time a simple clone out should suffice & a dry and/or wet cleaning method (whichever 'you' are comfortable with) should remove the offending item.
For myself I will be getting either Canon or Fixation to give it the 'under warranty' clean and then use the rocket blower as needed but based on the above I certainly will not (I hope ;) ) be sweating it about the dust because as I understand it I am very unlikely to see much if any dust in the airshow shots I will take because I think the smallest aperture I have used is f11 to get my shutter speed down to get prop blur.
For the record, as mentioned in another "subject" related thread, my 350D shows no dust in such normal usage and that is after two years.
The above are quick thoughts based on a rapid look at the images and I will be reviewing them again to confirm my thoughts & observations.
Have I made sense or totally lost the plot :lol:
Incidently, I notice when reviewing my sky images in Bridge there were odd circular 'diffraction like' patterns visible but once opened in CS2 they had disappeared - anyone seen similar and know why this happens??? Could it be that Bridge is using a thumbnail as the viewable image and as such this will show such artifacts under bright sky images?
That was a great meal ~ you must have a good set of pans :p
Images for a photographic memory (external link) | Flickr (external link) | >>>My 500px<<< (external link)
credit line is vanity, payment is sanity
Box ­ Brownie
Oct 21, 2007 13:58 |  #2
I realised that I forgot to mention that the 350D sky images do not have the same diffraction pattern in Bridge compared to what I have described above.
agedbriar
Oct 21, 2007 15:27 as a reply to  @ Box Brownie's post |  #3
The Auto Levels contrast increase on a dust test picture is an abnormally large one due to the unusually narrow starting histogram that's being stretched to the limits.
For this reason an Auto-Levelled test picture will show also dust spots that would not show up on a real picture with a reasonably broad histogram, even if they fell on a flat part of the scene and the real picture was taken at f/32 and Auto-Levelled as well.
tonylong
...winded
Gallery: 60 photos
Oct 21, 2007 15:51 |  #4
Dust problems vary with cameras and usage.
My rule of thumb is give the sensor a good bulb blasting occasionally, but if visible dust becomes an issue I have a sensor brush system (from VisibleDust.com) that comes highly recommended and then for last resort the Eclipse fluid/sensor swab solution. I've done a number of cleanings using some/all of the above and end up with clean sensors.
I've never used the Auto Levels approach, though -- I'd imagine that something like that will show up tiny things that won't bother "real" image/print viewing scenarios, at least from my experience. Nothing inthe real world can be "totally clean", just "clean for all practical purposes".
Tony
Tony
adifor
Oct 21, 2007 16:15 |  #5
Just checked my 40d after noticing a few dust bunnies,time to get the eclipse out i think :rolleyes: :D
1,221 views & 0 likes for this thread, 4 members have posted to it.
2712 guests, 150 members online
