I have a rebel xti and want to upgrade and I am torn between the 5D or the 30D. I mostly shoot portrait, some wedding but mostly portrait outdoors. Any pros and cons on both cameras would be helpful!!
reefergal Goldmember 1,056 posts Joined Feb 2007 Location: Oregon More info | Oct 21, 2007 00:33 | #1 I have a rebel xti and want to upgrade and I am torn between the 5D or the 30D. I mostly shoot portrait, some wedding but mostly portrait outdoors. Any pros and cons on both cameras would be helpful!!
liza Cream of the Crop 11,386 posts Likes: 1 Joined Feb 2005 Location: Mayberry More info | Oct 21, 2007 00:35 | #2 Permanent banThe 5D would be your best option, due to the superior image quality and performance at high ISO's.
shooterman village idiot, actually a genius! More info | Oct 21, 2007 00:58 | #3 If money is no object and you shoot mostly portraits, 5D would be the best option. Randy
jafrknb Member 213 posts Likes: 1 Joined Apr 2006 Location: Arizona More info | I would definately go for 5D ( actually just did) and then start investing in good glass...Tony anthonysoaresphotograpny.com
Thanks for the comments so far. What kind of an upgrade do you think the 30D is from the rebel xti?
Thornfield Senior Member 747 posts Likes: 1 Joined Dec 2004 Location: Christchurch New Zealand More info | Oct 21, 2007 06:53 | #6 Personaly I have no experience with the xti but do own a 20D and have just added a 5D body. Relationships are like photography, it has to click.
liza Cream of the Crop 11,386 posts Likes: 1 Joined Feb 2005 Location: Mayberry More info | Oct 21, 2007 11:04 | #7 Permanent banIf you're thinking about the 30D, I'd recommend the 40D instead.
AlphaChicken Knot Hank 3,569 posts Joined Aug 2007 Location: Asheville, NC More info | Oct 21, 2007 14:37 | #8 liza wrote in post #4164029 If you're thinking about the 30D, I'd recommend the 40D instead. Agree. I am Henry. NOT Hank. And certainly not a length of rope tied in a knot.
knt3424 Senior Member 520 posts Likes: 10 Joined Feb 2007 Location: Rockford, IL More info | Oct 21, 2007 15:25 | #9 correct me if I'm wrong, but doesn't the 5D have a full-frame sensor, so you will have to get all new glass for it, whereas if you go with the 40D, you can use all your existing lenses from the XTi? If that's the case, I would stay with the 40D, unless you really have an endless supply of money and want to upgrade everything...
AlphaChicken Knot Hank 3,569 posts Joined Aug 2007 Location: Asheville, NC More info | Oct 21, 2007 15:29 | #10 knt3424 wrote in post #4165165 correct me if I'm wrong, but doesn't the 5D have a full-frame sensor, so you will have to get all new glass for it, whereas if you go with the 40D, you can use all your existing lenses from the XTi? If that's the case, I would stay with the 40D, unless you really have an endless supply of money and want to upgrade everything... Agree with this too. Unless you already have a good range of full frame (EF NOT EF-s) lenses I would stick with the 40D. Or if you have the money to spend then go with 5D and plan on throwing alot more down afterwards. I am Henry. NOT Hank. And certainly not a length of rope tied in a knot.
Hinson Goldmember More info | Oct 21, 2007 15:54 | #11 knt3424 wrote in post #4165165 correct me if I'm wrong, but doesn't the 5D have a full-frame sensor, so you will have to get all new glass for it,... No, that's not necessily the case. Unless she has all crop lens now (which is highly unlikely) her current lens will will work better on the full frame 5D. I owned three crop bodies prior to upgrading to the 5D and never owned a crop lens. All of my lens now give the the POV they were designed for. Artist tools: Lumix FZ1000 (Canon 60D, 28/2.8, 10-22mm, Tamron 28-300mm VC ALL NOW FOR SALE - REASONABLE OFFER)
amonline Goldmember 3,558 posts Likes: 1 Joined Jul 2006 More info | Oct 21, 2007 16:39 | #12 40D and Glass. Why get a 5D when the replacement is on the way and you'll regret it?
TSEE Goldmember 4,961 posts Joined Mar 2005 Location: Middle of Nowhere, USA. More info | Oct 21, 2007 23:17 | #13 Personally I'd get the 5D, I've been drooling for the 5D for MONTHS myself, I'm probably a year from getting one myself. Lucky dog! -Sue (TSEE)
tonylong ...winded More info | Oct 22, 2007 01:32 | #14 reefergal, Tony
Oct 22, 2007 13:04 | #15 tonylong wrote in post #4168301 reefergal, I don't even want to ask about your name (geneologies can get so messy), but -- Can you afford a 5D? I have never heard a 5D owner say that they wish they had a different camera for portrait use. They just enthuse. I'm not a portrait shooter, but I do have a 5D, and can understand the quality issue/enthusiasm. So, get what you can afford -- if you can afford a 5D I think it's safe to say you won't regret it! Tony The name comes from that my husband and I own and operate a commercial refrigeration company. His screen name on Turbo Bricks was reeferman so I thought being the wife reefergal fit. We have both decided we should change our screen names for obviouse reasons. anyway, I can afford a 5D when your spending a grand allready what is a few more hundred? (in this case anyway) I don't want to spend that kind of money on the 30D and then wish I had spent a little more and got the 5D. I have been looking at photos on the this forum and noticeing what camera they are shot with and for my needs I am thinking the 30D, but I will check into the 40D as well. I realy like getting input from lots of dif. people who use the dif. bodies for dif. things such as portrait, wedding, action. I did not think about having to get new glass along with a new camera. New glass was not in the budget.
| Latest registered member is semonsters 1587 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
