Thread started 21 Oct 2007 (Sunday) 11:41
I am going to strangle HUEY!!!
Kai
Oct 21, 2007 11:41 |  #1
What should I do? I have Huey out reading the light but monitor is changing all the time. Dark - light -Dark - light ...... Just when I think my picture is good my monitor get darker and I am no longer satisfied. Does any one use the light reading part or should I say bad Huey and put him in the drawer?
PhotosByEric
Joined Jun 2005
Oct 21, 2007 11:46 |  #2
I always use the room light reader. If your screen in constantly changing maybe the light in the room is also changing which isn't a good thing. I always do the same thing, close the blinds and turn on a certain light so that the light is constant.
Eric
www.photosbyeric.smugm​ug.com (external link)
Canon 30D, Canon 15-85, Tamron 17-50 2.8, Canon 60 2.8 macro, 580exI, 430exI, st-e2, and a wish list a mile long:lol:
DreamCrushers in POTN FF
GertS
Oct 21, 2007 11:56 |  #3
Question: Has the Huey to be connected to the computer all the time for "adjusting"? :confused:
I set my Spider on the monitor, calibrate, remove the Spider from the computer and that's it.
- left forum in protest -
Kai
Oct 21, 2007 12:00 |  #4
Hey Gert... Yes you calibrate your monitor with the huey and then you keep it plugged all the time so it can read the light every couple minutes or so.
Kai
Oct 21, 2007 12:08 |  #5
ok... I watched it. This is what it is doing. Huey reads and my monitor looks nice and bright and then after a minute my monitor get about almost a whole stop darker and then Huey reads again and it changes back to light. Now when it changes from light to dark Huey did not read. This is driving me crazy. Maybe I should re-calibrate and see what happens?
GertS
Oct 21, 2007 12:26 |  #6
Hey Kai,
what kind of monitor are you using?
A TFT (a flat screen monitor) or a CRT (bulky with the heavy glass tube) ?
If it's a CRT, then it might be possible that the monitor is damaged and pumping light. With aging this can happen.
If you don't have the HUEY connected, does it pump too?
Good luck
picturecrazy
soft-hearted weenie-boy
Oct 21, 2007 12:42 |  #7
I never turn on the auto adjusting for room light. That would drive me nuts. Just use consistent lighting in your work area and you should be good. It might be positioned so it's reading some of the light off your screen and trying to adjust to that. Are you editing in a very dark room? Is the huey pointed towards to the screen, even a tiny bit?
-Lloyd
The BOUDOIR - Edmonton Intimate Boudoir Photography (external link)
Night and Day Photography - Edmonton Studio Family Baby Child Maternity Wedding Photographers (external link)
Night and Day Photography - Edmonton Headshot Photographers (external link)
Facebook (external link) | Twitter (external link) |Instagram (external link) | Gear
Kai
Oct 21, 2007 12:47 |  #8
Thanks guys. No, the light in the room is not consistent. It is my bedroom. I recalibrated and I have not had the problem. I wonder if it was reading the monitor like lloyd said.
I did have my husband come and cover some windows. I will try to get it more consistent.
Dorman
Joined Feb 2006
Oct 21, 2007 13:24 |  #9
I use the huey as well but I turn off room lighting compensation and try to recreate the same lighting when I edit each time.
1,810 views & 0 likes for this thread, 5 members have posted to it.
1852 guests, 108 members online
