gjl711 wrote in post #4175743
Silica gel packs are pretty useless as they have a limited capacity to absorb moisture. If you bake them dry the night before, it may be able to suck up the moisture originally in the bag but open a few times and they will saturate. Also, they absorb moisture very slowly, great for shipping but not dehumidification. Also gradually letting the camera warm up does nothing as well. The best advice is to keep the warm moist air away from the equipment in the first place. This is where plastic bags like Ziploc comes in real handy. Seal up the bags outside and don’t open them until the temp has come up. If you have been out for a long time, give it a little more time for the innards to warm up as well.Another thing you can do is pickup these hand warmer packs. You can get them at your local sporting goods store or here in Chicago I have seen them at drug and grocery stores as well. They are pretty cheap and last for about 6~8 hours. Keep them in with the lenses in the Ziplocs and the lenses stay nice and toasty thus greatly reducing the time it takes to get the lens above the dew point temperature. I tried this last January while at the zoo. Going into the tropical house from the sub-freezing outdoors and the lenses were ready to use and condensation free within only minutes instead of the normal ½ hour I usually had to wait. Silica gel packets are fine. If your gear is in a bag where most of the air has been squeezed out, the potential amount of condensation is more than enough for a silica gel packet or two to handle. As for silica gel packets only being good for dehumidification, that's where letting your gear warm up gradually comes in. Obviously you want to minimize the chance of moisture building up in the bag and the silica gel packets are there as a safeguard. Used in this fashion, the system works perfectly.
As for gradually letting the gear warm up doing nothing, every six grade science book would disagree with you. Condensation forms when warm air touches a cold surface and the water molecules condense on the surface. The reason why your hand warmer technique works is because they keep your gear above the dew-point temperature relative to the place where you unpack your gear. I'm glad that it works for you but not every outing is a trip to the zoo and Chicago winters are tropical compared to some places. The number of hand warmers that you could potentially go through on a extended trip is bad enough not to mention the fact that one could easily run into a situation where the hand warmers are not capable of keeping their gear above the critical dew point temperature. If that happens, pray that you have some silica gel packets on hand. Lastly, silica gel packets are very compact and light compared to hand warmers. I don't know if you have ever done any mountaineering but every single ounce of gear counts, especially when you start getting above 5000 meters. I don't disagree that your method may work for you but it does not make every other method 'useless'. I've been using using silica gel packets for travel to my last 30 or so destinations and it has protected my gear perfectly. I'll keep the hand warmers for my hands.
Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
