I see how to have 3 bracketed exposures w. changing aperature on the XTi. Is there a way to have bracketd exposures for shutter speed, other than manually? (I want to try beginners' version of HDR)
Thanks,
margery
margery Hatchling 3 posts Joined Nov 2006 More info | Oct 22, 2007 11:35 | #1 I see how to have 3 bracketed exposures w. changing aperature on the XTi. Is there a way to have bracketd exposures for shutter speed, other than manually? (I want to try beginners' version of HDR)
ggw2000 Senior Member 299 posts Joined Sep 2006 Location: Upstate NY More info | Oct 22, 2007 13:27 | #2 margery wrote in post #4170313 I see how to have 3 bracketed exposures w. changing aperature on the XTi. Is there a way to have bracketd exposures for shutter speed, other than manually? (I want to try beginners' version of HDR) Thanks, margery Put the camera in A/V mode and select your aperture. Set your bracketing to the amount you want. Set the camera to high speed mode. Camera will take 3 pictures with different shutter speeds. This is the only way that you should be doing HDR. You want the aperture the same all the time..
koalawalla Member 169 posts Joined Aug 2007 Location: Lynnwood, WA More info | Oct 22, 2007 22:34 | #3 Couldn't have said that better myself. I use bracketing all the time in my night shots for car photography Canon 40D | EF-S 17-55 f/2.8 IS w/ ridiculously overpriced lens hood | EF 70-200mm f/4L | EF 15mm f/2.8
| Latest registered member was a spammer, and banned as such! 2426 guests, 106 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
