Thread started 22 Oct 2007 (Monday) 20:58
Multi colored pixels
RichNY
Oct 22, 2007 20:58 |  #1
I went out tonight and took a few ISO 1600 shots with my 1DIIN and noticed that I have 2 red pixels, a blue pixel, and a green pixel appearing in the same spot of every shot. A bit underexposed.
These dots did not appear in this weekend's ISO 1600 properly exposed hockey shots.
I've heard of dead red pixels but never blue and green pixels appearing. Does anyone know what causes these? I haven't had a chance to test out under what conditions they do/don't appear yet.
Nikon D3, D300, 10.5 Fisheye, 35 f/1.4, 50 f/1.4, 85 f/1.4, Zeiss 100 f/2, 105 f/2.5, 200 f/4 Micro, 200 f/2, 300 f/2.8, 14-24, 24-70, 70-200, SB-800x4, SB-900, SU-800, (3) Sunpak 120J (2) Profoto Acute 2400s,Chimera softboxes, (4)PW Multimax, (6) C-stands, (3) Bogen Superbooms, Autopoles
braduardo
Oct 22, 2007 21:46 |  #2
I would guess that they are 'hot' pixels. You would most likely get the same result by taking a 30sec exposure with the lens cap on. You should try that and see if you have any hot pixels. I don't know if there is any real 'fix' for them, but just knowing that they are there might be useful.
:rolleyes: ----Brad---- :rolleyes:
www.nybergstudio.com (external link)
40D: EF 17-40 f4 L ---- EF 70-200mm f4 L ---- EF 50mm f1.4 ---- EF 85mm f1.8
twofruitz
Oct 22, 2007 22:35 |  #3
I had my 40d replaced because of the exact same thing... it cant be fixed and it may get worse... send back to canon if you can for a fix.
Jon
Joined Jun 2004
Oct 23, 2007 11:59 |  #4
If you're taking long exposures, you'll generally get hot or dead pixels showing up - and by "long" we're talking anything much over 1 sec. If you have a problem with them in the "normal" (1/30 sec. and faster) shutter speeds, you have a problem; if you're in long exposures, it's the rare camera that doesn't have them.
Jon
Cocker Spaniels
Sgt_Hovanec
Oct 23, 2007 12:16 |  #5
I've had grey blue green red purple turquiose and others across the gamut. I agree with what Jon said about the length of the exposure. Mine always shows during 20+ sec exposures only, which is usually normal with the heat in Florida. They should not show up on average speed exposures though.
My Gear List - Lightning Photography Extremist
1,028 views & 0 likes for this thread, 5 members have posted to it.
1338 guests, 136 members online
