If you are getting sharp images with your Peleng please enlighten me as to how you are using this camera on your Canon. I have the mounts in the picture below.
![]() | Byte size: ZERO | Content warning: NOT AN IMAGE |
As you can see the T mount on the left, the M42 to EOS mount and another I don't know where that came from mount. It seems that I have to use the mount on the right with the EOS mount to get this thing on my camera since the EOS mount does not fit the Peleng by itself. Is this what everyone was referring to when they said the T mount was too big? Using the EOS and the other mount together is almost as thick as using the T mount. Is there an EOS mount that will fit the Peleng on it's own? This current setup does get a little bit closer to the sensor but I was expecting much closer because of what everyone was saying. No one mentioned this extra mount in addition to the M42 to EOS mount.
Thanks in advance. Pictures of your setup is welcome. SEV I am hoping that you can post a picture of how you mount this lens on your camera. Thank you.
- Andrew
