My budget is always dominating my decisions now
Just wondering if this is TOO wide for the 5. Any example photos would be great too.
Peace out!
adamLC Goldmember 2,142 posts Joined Dec 2006 Location: Greenhithe, Kent. U.K More info | Oct 23, 2007 14:02 | #1 My budget is always dominating my decisions now EOS 6D, 135L, 24-105L, Mamiya RZ67pro2 and lenses
asylumxl Goldmember 2,306 posts Likes: 1 Joined Jul 2006 Location: Stuck in an invisible box More info | Oct 23, 2007 14:15 | #2 No such thing as too wide ...............
LightRules Return of the Jedi 9,911 posts Likes: 5 Joined Jun 2005 More info | Oct 23, 2007 14:46 | #3 Adam posted this a while back at DPR http://forums.dpreview.com …rum=1029&message=23929342
Oct 23, 2007 14:56 | #4 LightRules wrote in post #4177892 Adam posted this a while back at DPR http://forums.dpreview.com …rum=1029&message=23929342 I thought "I posted no such thing!".... like I'm the only Adam on the planet EOS 6D, 135L, 24-105L, Mamiya RZ67pro2 and lenses
jacobsen1 Cream of the Crop 9,629 posts Likes: 32 Joined Jan 2006 Location: Mt View, RI More info | Oct 23, 2007 15:12 | #5 I had one for my 5D. I had originally bought it for the 1DmII figuring I'd keep it once I went FF, but 12mm was too wide (I'd always shoot at 12mm, then images would need to be cropped once I got them home) and it's not as sharp as what I replaced it with (17-40mm L). It's a great lens on a 1.3, and it works well on FF I just wanted sharper images and realized I was using 12mm too much because it was there. My Gear List
jacobsen1 Cream of the Crop 9,629 posts Likes: 32 Joined Jan 2006 Location: Mt View, RI More info | Oct 23, 2007 15:13 | #6 more: My Gear List
Dylanlewis2000 Senior Member 444 posts Joined Apr 2006 Location: Swansea More info | Oct 23, 2007 15:15 | #7 those look loverly! Canon 400D, Canon 17-85 IS USM, Canon 50mm f/1.8, Sigma 100-300 F/4 DG EX, Sigma 150mm F2.8 MACRO EX, Jessops Extention Tubes, Jessops X2 Tele.
Oct 23, 2007 15:21 | #8 Thanks for the gallery Jacobsen1 EOS 6D, 135L, 24-105L, Mamiya RZ67pro2 and lenses
jacobsen1 Cream of the Crop 9,629 posts Likes: 32 Joined Jan 2006 Location: Mt View, RI More info | Oct 23, 2007 15:22 | #9
adamlc wrote in post #4178060 Thanks for the gallery Jacobsen1 I think they're great shots, I can't tell any softness because of the size though. The prespective is perfect for what I want, I read a bit about the sharpness of this lens. If it's not sharp enough then I'll get it callibrated... if that doesn't work then I'll think of something else. On the whole, I'll probably end up buying this lens. Thanks again for the examples, top man! no worries. It's a great lens. Some people say I had a very good copy. It wasn't perfectly sharp and it had a yellow cast to it. Nothing a little PP won't fix, but I wanted a sharper lens, and that's what I got. Also consider the 17-40mm L for the same money. My Gear List
Oct 23, 2007 17:08 | #10 jacobsen1 wrote in post #4178065 Also consider the 17-40mm L for the same money. Why do you need 12mm BTW? It's VERY wide. It's more a want than need EOS 6D, 135L, 24-105L, Mamiya RZ67pro2 and lenses
jacobsen1 Cream of the Crop 9,629 posts Likes: 32 Joined Jan 2006 Location: Mt View, RI More info | Oct 23, 2007 17:22 | #11 I've found the 17-40mm to be perfect. It's also a better range for a walk around for me on the 5D. Before I'd be swapping between the 12-24 and the 24-70 all the time as the 12-24 is ONLY a UWA. Now with the 17-40mm it lives on my 5D75% of the time and I love it... I also picked up a 15mm FE for when I need wider than 17mm. It's better than the 12mm for me because the 12mm was too wide for normal shooting. The FE perspective makes me use it when it works, but not all the time. It was a better solution for me, but try both if you can. My Gear List
| Latest registered member is semonsters 1176 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
