Thread started 24 Oct 2007 (Wednesday) 08:21
Mirror lock up on 40D
sinitry23
Oct 24, 2007 08:21 |  #1
How do I enable the mirror lock up function on the 40D?
Also when I use live view mode I hear something that sounds like it opens up in side the body. Is that the same as mirror lock up? I want to get the most sharpest pictures I can get while shooting landscape.
http://www.william-chang.com/ (external link)
Mr. ­ Plow
Oct 24, 2007 08:42 |  #2
Menu - C.FnIII-7 - Enable
When using live view mode the mirror is flipped up out of the way.
sinitry23
Oct 24, 2007 09:17 as a reply to  @ Mr. Plow's post |  #3
So using "live View" is similar to mirro lock up right?
Jon
Joined Jun 2004
Oct 24, 2007 09:58 |  #4
Well, the mirror's locked up while you're in Live View. But there's a lot more to it than that.
Jon
Cocker Spaniels
sinitry23
Oct 24, 2007 21:31 |  #5
Jon wrote in post #4182606 (external link)
Please explain...
If I was to shoot landscape is it better to lock the mirror and then snap the shot or use live view and snap the shot?
tonylong
...winded
Gallery: 60 photos
Oct 24, 2007 21:42 |  #6
Mirror lockup is useful when you use a tripod, such as for landscapes and macros (but not for things such as action and continuous shooting). For fast shutter speeds it's not so useful, but if you are in dim light and/or use a narrow aperture then mirror lock will help you to not expose as the camera vibrates from the mirror snapping back. I use it extensively with my tripod work.
To use mirror lockup you have to enable it in the Custom Function, then when you press the shutterspeed the camera will set focus and exposure (unless you did these manually) then the mirror will open and lock. You wait a little bit for the vibration to die down, then press the shutter button a second time and the image will be captured.
Your manual expains this procedure -- I suggest you give it a good reading to familiarize yourself with the operation of a very nice camera!
Hope this helps,
Tony
Tony
marcus769
Oct 25, 2007 00:00 |  #7
I set it to a custom function and sorted it to the top (CF1).. Its super fast to access this way... I also use it for tripod work and have discovered its not so good for in hand camera work if you have to constantly keep moving it and aiming everywhere... It helps tremendously on the tripod for landscapes thats for sure...
7D, 40D, 28-135mm IS, 50mm 1.8 II, 100mm 2.8L, 70-200mm 2.8L IS, 580 ex II
nutsnbolts
Oct 25, 2007 00:15 |  #8
Ok, what is mirror lock up. I have heard it but what do you use it for?
Canon EOS 40D | EOS Rebel XTI/400D | G9
Lenses and Gear List
Review of my ThinkTank Gear
AperturePriority
Location: Beautiful, Sunny, and Warm Southern California!
Oct 25, 2007 02:02 |  #9
nutsnbolts wrote in post #4187241 (external link)
When you shoot a photo, the mirror swings up and out of the way, so that the light can hit the sensor. The mirror is so you can see the image in the viewfinder (it reflects the light up into the viewfinder).
The swinging up of the mirror causes vibration that can "blur" a photograph under certain conditions.
Locking up the mirror eliminates this vibration that the mirror produces.
Remember, I said "under certain conditions". It's late where I am so I'll let the masses here expound on those conditions... :)
-Canon EOS 40-D with vertical/battery grip, wireless remote shutter release
-Canon 10-22mm F3.5 USM (with hood)
-Canon 70-300mm F4 EF IS USM (with hood)
-Canon 28-135mm F3.5 EF IS USM (with hood)...and many more items.
-Check out my photography here (external link). And here (external link), too.
xarqi
Oct 25, 2007 02:47 |  #10
OK - so the unanswered question here is if using liveview provides the same advantages for vibration reduction as using mirror lock-up. Any opinions/data on this?
BogongBreeze
Oct 25, 2007 03:25 |  #11
xarqi wrote in post #4187727 (external link)
Because the mirror is locked up in live view, the answer is yes.
Miriam
Canon 90D and various lenses
xarqi
Oct 25, 2007 03:53 |  #12
BogongBreeze wrote in post #4187792 (external link)
Cool - another advantage of liveview that I hadn't fully appreciated. In fact, the whole PITA MLU issue just went away, as far as I can see.
tzalman
Fatal attraction.
Oct 25, 2007 04:50 |  #13
AperturePriority wrote in post #4187633 (external link)
The condition is that it is effective only in the range of shutter speeds 1/30 down to 1 second. Faster than 1/30 the speed "freezes" the mirror caused camera motion while slower than 1 second the time when there are vibrations is such a small part of the total exposure that it is inconsequential. Some people do say that the range is 1/60 - 2 sec. and others use it even more, according to the philosophy of "If it doesn't hurt, why not use it?"
Elie / אלי
tzalman
Fatal attraction.
Oct 25, 2007 04:54 |  #14
xarqi wrote in post #4187848 (external link)
Precisely, and with the bonus that you don't lose eye contact. OTOH, use it sparingly to avoid heat generated from LV raising the noise level.
Elie / אלי
BogongBreeze
Oct 25, 2007 05:00 |  #15
Don't forget that you'll probably negate any benefit unless you use MLU on a tripod with a cable release. Just pressing the shutter button will probably give a vibration greater than that of the mirror itself.
Miriam
6,904 views & 0 likes for this thread, 11 members have posted to it.
2706 guests, 140 members online
