Thread started 24 Oct 2007 (Wednesday) 11:44
Cleaning the sensor
greatshot
Oct 24, 2007 11:44 |  #1
How should I clean the sensor on my XTi? Is it better to send it in and let canon do it or is it better to do it my-self? Dose anybody have any experience with this?
Thanks,
Greatshot
7D:), XTi, 18-55, 28-135 IS, Canon 100-400:) 17-40:)
Please visit my site: www.jakeorr.com (external link)
It's not the gear that makes the picture...........It's the photographer.
PhotoJourno
High Plains Chimper
Oct 24, 2007 11:54 |  #2
The XTi seems to be the same self cleaning sensor system as the 40D, or at least the same principle. I am assuming that there are specks that are firmly attached to your sensor filter, and that will not just shake off. (And that for some reason the dust detect system from Canon software is not working for you, or to your satisfaction).
A trip to canon is going to be around $200. Here is what I would suggest:
- Find a local Photo repair in your area, and have them clean it for maybe $50.
- Risk to do it yourself, usually not as hard when you follow the rules. I use a little air blower (just a rubber bladder that you press and pushes air through a nozzle, much like those ear cleaners they sell at pharmacies. And blow on it gently. Problem is, sometimes you end up moving more dust from inside the camera than usual. Precautions are to avoid touching the surface of the filter/sensor at all times, and to never use canned air, or any other idea as creative as it might sound (qtip, toilet scrub brush, etc).
If the sensor cleaning goes wrong, a trip to canon will probably result on a main board change, maybe even a mirror assembly replacement, and quite a bit of money out of your pocket.
My opinion, anyways. Best of luck.
--Mario
"Sensa luce non si vede nessuna cosa"--Lorenzo Ghiberti
Jon
Joined Jun 2004
Oct 24, 2007 11:54 |  #3
Learn to do it yourself. You don't want to be sending it off for a couple of weeks every month or so. There are directions here (external link) among other places. Most people start with a Rocket Blower when they start seeing dust spots. Then they may go to Sensor Swabs or to the Visible Dust Arctic Butterfly.
here and here are threads on it as ell. There are plenty more to be found if these have whetted your appetite.
Jon
Cocker Spaniels
John_B
Gallery: 178 photos
Oct 24, 2007 12:16 |  #4
greatshot,
My first suggestion is to use a Giottos Rocket blower (click to see the one I use) (external link) as this might clean it good enough. If that doesn't work then a wet cleaning is next in line in my book. If you feel you can be careful then do it yourself with something like the Copperhill cleaning kit click to see (external link)
Of course if you don't feel comfortable then send it to Canon :)
greatshot
Oct 24, 2007 12:17 |  #5
Canon said it might be under warranty because I have had it for under a year and I could send it to them and they would see if it was and if not they would send it back, do you think I should do that or just get some sort of blower and do it my-self?
Thanks,
Greatshot
Jon
Joined Jun 2004
Oct 24, 2007 12:20 |  #6
get the stuff to do it yourself. It won't be the last time your sensor needs cleaning. Even if it's under warranty this time, it won't be next time. They do do sensor cleanings (in the US at leat) on a free, walk-in basis, but you're still tied up for the visit.
Jon
Cocker Spaniels
greatshot
Oct 24, 2007 12:20 |  #7
Are you supposed to get a sensor cleaning program disk for you computer when you get your camera?
PhotoJourno
High Plains Chimper
Oct 24, 2007 12:24 |  #8
Should be included on the Canon CDs that come with the camera.
--Mario
Jon
Joined Jun 2004
Oct 24, 2007 12:24 |  #9
No. the computer doesn't come into the issue. You may be thinking of the dust-reduction mode whereby you can photograph your dusty sensor, save that as a template as it were, and let Digital Photo Pro apply that dust image to all your RAW photos to help cancel out dust spots in your photos.
Jon
Cocker Spaniels
greatshot
Oct 24, 2007 12:25 |  #10
Ok I never did look into the CD's thanks I"ll do that.
greatshot
Oct 24, 2007 18:51 |  #11
I tried blowing the sensor off and it did not work what is your next solution?
Thanks,
Greatshot
silvex
Gallery: 21 photos
Oct 24, 2007 19:53 |  #12
https://photography-on-the.net/forum/showthre​ad.php?t=395285
-Ed
CPS Platinum Member.
Canon Gear
SilvexPhoto.comexternal link
1,311 views & 0 likes for this thread, 5 members have posted to it.
Cleaning the sensor
2711 guests, 140 members online
