I suspect that the luminous-landscape one is better, but this is the one I used &, if nothing else, it will serve as a bad example!
So, you've got an image of a polished aluminum aircraft in the bright sunlight, & half the pic is blown out.
I started with this Tut: Adjustment layer basics![]()
Another way to do it is on:
http://www.luminous-landscape.com …/u-contrast-masking.shtml
This one says, "# Use Gaussian Blur to reduce resolution degradation of the image by the mask, yet at the same time avoid halos on sharp contrast boundaries such as skylines. (Filter / Blur / Gaussian Blur). Low amounts are usually best."
Well, I read that after I processed the pic using the first Tut, & you can see the halo around the prop & top of the cowling. In 'Step 4', I used a 10 pixel radius for the blur, & should have noticed that!
Here's a look at the two different exposures extracted from RAW. If I remember correctly, The 'under' one was -2.0 & the 'over' one was +0.5. Getting 'over' was easy, so I used the pilots head as a guide to set the exposure.
The final image:
Not perfect, but better than what I had.
A gallery of two pages of pics here:
http://img72.photobucket.com …tosGuy/Air%20Show%202004/
The first post of the "$2,000,000 Lawn Mower! (Air Show)", pics is here, with pic info, etc.
UPDATED 11/4/04
In ran across "Adobe digital photography white papers and primers" at:
http://www.adobe.com …limag/ps_pro_primers.html
The "Highlight Recovery in Adobe Camera Raw" on that page gives a much more detailed tutorial on contrast control using a different method of selecting the highlites. This is a 'must read'.
by Jeff Schewe
"The best digital cameras have about the same dynamic range as transparency film, but with Adobe Camera Raw you can actually process your raw images to pull out more highlight detail than you may have thought possible."
EDIT 3/21/05: I found another one. It's a lot easier & seems to bring details of darker pics as well as have applications to blown pics, too. If I remember right, you'd use Screen Mode for the overexposed ones. Any way, have fun. You'll learn something either way!
Blend modes for Contrast Masking:
http://www.luminous-landscape.com …ls/contrast_masking.shtml
More on Blend Modes:
Photoshop's Five Essential Blend Modes For Photo Editing
