Thread started 24 Oct 2007 (Wednesday) 14:57
How do you select White Balance?
jlvpeng
Oct 24, 2007 14:57 |  #1
Hey, guys
I have two cases.
1. When you shoot indoor sports, How do you guys select white balance?
2. During traveling, how do you select white balance?
Last question, how often you use gray card?
My Gear List and Market Feedback
http://www.jlvpeng.comexternal link
lungdoc
Oct 24, 2007 15:06 |  #2
I shoot RAW for everything and select it in post, you can use a grey card or white card for that to be perfect, for my amateur needs I just pick a white object from the scene so it looks right.
If forced to use in-camera method I think the simplest is the Expodisc method using custom WB - do a search for details. I have tried this using a white coffee filter since I am cheap and it works remarkably well.
Mark
My Smugmug (external link) Eos 7D, Canon G1X II, Canon 15-85 IS, Canon 17-85 IS, Sigma 100-300 EX IF HSM, Canon 50mm 1.8, Canon 85mm 1.8, Canon 100mm 2.8 Macro, Sigma 50-150 2.8, Sigma 1.4 EX DG , Sigma 24-70 F2.8 DG Macro, Canon EF-S 10-22, Canon 430EX,
vic6string
Oct 24, 2007 15:32 |  #3
I used to just use a coffee filter I kept in my bag, but now I shoot in AWB and fix it in post processing. Ever since I discovered how easy it is to make huge improvements in my pics using DPP, I PP everything, and it is just easier to shoot in AWB and fix the WB later. And if shooting RAW doesn't work for you, it doesn't matter as it is just as easy to fix white balance in DPP on jpegs.
Rebel XTi, 430ex, Tammy 28-75, nifty fifty, kit lens, tons of reading, not enough practice, and two gorgeous subjects (my kiddies)
thatkatmat
Gallery: 41 photos
Oct 24, 2007 16:26 |  #4
Yeah, I do the same AWB, I bought a white/grey card but never seem to use it as I usually am shooting on the fly...Sometimes I spot...but usually AWB+Raw, I process just about every shot I take so If WB is off a bit I use the little dropper tool to spot balance a white object. I will however use the cards if I'm setting up a like a portrait shoot
My Flickr (external link)
Stuff
lungdoc
Oct 24, 2007 16:31 |  #5
Although newer software like DPP and Lightroom can fix WB on jpgs it isn't the same as doing it with RAW - you have discarded data by the time it gets to jpg and manipulating remaining data will give some quality loss. For many purposes that loss may not be noticeable or significant.
Mark
amfoto1
Oct 24, 2007 18:08 |  #6
Like others, I mostly just do it in post processing, if needed. But, I shoot mostly RAW where it's easy to change, too.
I try to watch out for situations where lighting might be a problem... example, mixed light sources, or nasty ones like sodium vapor. I have a small set of cards in my bag, to set custom white balance, if needed. Among the set are neutral, warm, extra warm, cool and two fluorescent types of biases.
I also have a gray card, but only use it for exposure checks.
I'd love to have a color meter, and am glad to see Kenko has picked up the old Minolta meter line. Some day when I have an extra $900 that's not going toward lenses or bodies, I might get one!
KirkHMB
Oct 25, 2007 11:14 |  #7
Indoors, I have a gray card, and try to set it off that. Or, I'll use someone's white shirt if I forget my card. When either of those don't work, I'll start spinning through the choices on the 30D until something looks reasonable on the LCD.
If all those methods barf, I'll use the color cast button in ACDSee.
Shoot JPGs for everything.
shooting club VB and club soccer, hoping to get back to landscape work soon.
ed ­ rader
"I am not the final word"
Oct 25, 2007 11:17 |  #8
KirkHMB wrote in post #4189483 (external link)
i've done that plenty of times :D.
if there is ever a time to shoot RAW it's indoors.
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
queenbee288
Gallery: 17 photos
Joined Dec 2004
Oct 25, 2007 12:36 |  #9
I find that my camera does a good job outdoors with AWB. If it is indoors I will do a custom white balance if it something important but not if it is just snaps. I shoot everything raw but I find that custom white balance is still better when it really matters or if the lighting is weird.
Wekkel
Oct 25, 2007 13:43 |  #10
I take the easy route. Shoot everything in RAW and upon import in CS2 with Adobe Raw, I select Auto for the White Balance and take it back to original if needed on a case by case basis. It's a great procedure to get indoor shots that get very yellow/orange back in line.
Anders ­ Östberg
Joined Nov 2003
Oct 25, 2007 14:04 |  #11
For icehockey I set the WB off the ice. For other sports I try to remember to bring a sheet of A4 paper - I should go put one in my camera bag now. If I don't have a suitable white object I just use AWB and set the white balance when converting the RAW files.
I bought a set of WhiBal cards ages ago but sort of forgot about it and it has been sitting in a drawer. I need to bring that out and try it.
Anders Östberg - Mostly Canon gear - My photos (external link)
number ­ six
fully entitled to be jealous
Oct 25, 2007 14:07 |  #12
Others have reported getting a good white balance reading from their Canon lens cap. Obviously this would be one with just silver and black, not one with "ultrasonic" in gold.
I haven't tried this yet, I keep forgetting...
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
dpastern
Oct 26, 2007 06:26 |  #13
Shoot RAW, set the camera to AWB, change as needed in DPP, Adobe Camera RAW, etc etc. Outdoor, AWB seems to mostly work OK, indoors it's not great imho. A grey card isn't a bad idea, providing the light that you test the grey card with is the same as your subject. If you can get the white balance correct in camera, it will save you time in PP later on, and that's always desirable imho.
Dave
Gatorboy
Oct 26, 2007 07:40 |  #14
I set the WB the same way regardless of indoors or outdoors. Press the WB button and spin the dial until the white balance I want to use comes up.
Dave Hoffmann
wile_e_coyote_n_taz
Oct 26, 2007 08:58 as a reply to  @ Gatorboy's post |  #15
At my daughters cheerleading and basketball games I use the coffee filter trick to set custom WB and shoot RAW. I find that getting the white balance right saves me time PP later. I shoot everything RAW.
bill
When life hands you lemons: add tequila and salt!
2,490 views & 0 likes for this thread, 16 members have posted to it.
Latest registered member is Sandro Bisotti
1691 guests, 167 members online
