Took my 50mm 1.4 into work to let a workmate try it on his 350D. When he was putting my lens on his camera he was super careful as most people are when they use other peoples stuff. He took quite a few shots then gave it back to me.
Lens caps were on and the hood was on (inversed). I am turning it over in my hands as we are chatting for about 5 minutes. What a great lens it is etc. Next thing I know it is rolling out of my hands and heading for the floor. Solid office carpet and my fifty come into contact with a horrbile sound.
Gently pick it up but the rattle of broken glass doesn't sound good. Take the front lens cap off and
the uv filter is in a million pieces, please let that be all I am thinking. Empty glass gently into bin then try and unscrew the filter (or what is left of it) it doesn't budge. Gently lift out a few large pieces of glass that are left attached to the filter ring. Doesn't look like there are any scratches on the front lens, but I still cant budge the filter ring. OK I think I will wait until I get home and try a small pair of pliers to get a good grip.
That evening, I try the pliers. No movement at all. In fact I have deformed a little the filter ring as the tip of the pliers are straight and the ring is of course a, well,mmm, ring. The lens cap just fits and no more. Tried it on my 20D and the lens seems to work fine the filter lets through 100% of available light, which you would expect from a filter with no glass
So what to do now. The lens works, I dont want to force anymore in case the ring bends and I cant get the lens cap on. No chance of stacking another filter on top but that does not really bother me. Less need for a CP on a 50mm than wider angles. It is not too pretty but I guess that is not too important. Would canon/camera repairer be able to fix it (remove the ring?)
Anyway it could be better but it could have been a hell of a lot worse.
cheers
Ali
