Hi Folks
I see to be getting a green cast from my new 40d.
Especially happens in Low Light.
I've trien reseting the factory setting, but still no difference.
When I shot in RAW it can be easily corrected, but time-consuming.
Any thoughts?
golden-balls Member 88 posts Joined Nov 2003 More info | Oct 25, 2007 15:37 | #1 Hi Folks
30DShooter Senior Member 331 posts Joined Jun 2007 Location: San Diego, CA More info | Oct 25, 2007 15:38 | #2 Your WB is off. I can tell cause that sign in the back, "Pool G", is a white piece of paper, but it looks grey in the photo.
queenbee288 Cream of the Crop More info | Oct 25, 2007 15:50 | #3 Gymnasiums usually have that funky green lighting. Do a custom white balance next time.
numbersix fully entitled to be jealous 8,964 posts Likes: 109 Joined May 2007 Location: SF Bay Area More info | Oct 25, 2007 16:28 | #4 Agree with Char. I played with color balance on your shot and I like the results best using the eyedropper on the white floor they're standing on. "Be seeing you."
elader Goldmember 2,374 posts Likes: 1 Joined Nov 2005 Location: Maryland More info | Oct 25, 2007 18:55 | #5 auto white balance sucks big time under gym lights. Get a gray card and set a custom Wb. Eric
Mark_Cohran Cream of the Crop More info | Oct 25, 2007 23:01 | #6 You were probably shooting under florescent lighting which is notorious for messing with your color balance. As others have said, a custom white balance will help a lot, but even then depending on what the frequency output of the lighting is when you snap the shutter, it can still cause a slight color cast to your photos. When shooting under florescents, I'v'e found your much better off to shoot RAW and then adjust the white balance in conversion. Mark
tonylong ...winded More info | Oct 25, 2007 23:12 | #7 elader wrote in post #4192029 auto white balance sucks big time under gym lights. Get a gray card and set a custom Wb. Agreed, especially if you'e shooting jpeg. Another thing you might try if you shoot under these conditions a lot is an Expo Disk. Tony
| Latest registered member was a spammer, and banned as such! 2715 guests, 140 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
