Thread started 28 Oct 2007 (Sunday) 10:32
10D converted to IR.
rick ­ j
Oct 28, 2007 10:32 |  #1
what does this mean?? have seen a few people have posted they have had there 10D converted to IR. but havent got a clue what they are taliking about  :o is it something I should have done to mine??
www.ichiban-koi.co.uk (external link)
1D mk3, canon 17-35 L CANON 28-70L, canon 70-200 f2.8L IS canon 300 L f4 is, canon 100mm macro, 580EX SPEEDLITE, DYNATRAN AT-828, Giottos MM 9570
tiktaalik
Joined Feb 2006
Oct 28, 2007 10:41 |  #2
The IR conversion makes it easier to take infrared photos. Camera sensors are very sensitive to infrared and normally have a filter to block this portion of the spectrum. In a conversion, this filter is removed and another put in place that blocks non-infrared wavelengths. A converted camera will take a photo in infrared with normal daylight exposure times.
Don't do this to your 10D unless you want to take infrared only photos. People generally convert their 10D when they have newer bodies for regular shots and the 10D is just lying around not being used at all.
Here's a shot from my converted 10D:
Typically vegetation will show up white and the sky will be black or very dark.
Julie
My galleries (external link)
https://photography-on-the.net …hp?p=1330884&po​stcount=56
rick ­ j
Oct 28, 2007 10:49 as a reply to  @ tiktaalik's post |  #3
thanks for the quick reply something else I have learned today :) and something I dont need to spend money on :lol:, great pic by the way
TMR ­ Design
Joined Feb 2006
Oct 28, 2007 10:53 as a reply to  @ rick j's post |  #4
I've dabbled a bit and come up with similar results when I use an infrared preset in Lightroom. I wouldn't convert a camera but I suppose for some it makes more sense to have a dedicated IR camera that shoots that way and eliminates the PP step.
Robert
Jon
Joined Jun 2004
Oct 28, 2007 11:10 |  #5
It also gets exposures down to reasonable levels rather than the 30 sec. or so you need using an unconverted camera with an IR filter. But converting a camera to IR won't eliminate the PP step, just as an action on an unfiltered shot won't give you real IR.
Jon
Cocker Spaniels
johneo
Joined Aug 2003
Oct 28, 2007 12:52 |  #6
rick j wrote in post #4206061 (external link)
IR (Infrared) is just another aspect in the world of photography. Something else to play around with.
I saw a few IR shots a few years back and liked it. Bought a IR filter and what a pain! Long exposures and lots of practice. Then I found out about converting a digital camera to IR.
You ruin the camera if converted as it doesn't take quite the same type of photos :) But if you want to get IR photos, it's the best way to go.
i had my older 10D converted and find myself shooting a lot with it, trying to get some good shots. Got the 10D back about a month ago and having a lot of fun.
http://mysite.verizon.​net/johnori/7634f.jpg (external link)
2 - 5DMKII's, Powershot SX 150 IS
7D, 5D, IR/5D, 10D, IR/10D, Elan 7NE
17-40 L, 24-70 L, 70-200 f/2.8 L IS, 100-400 L IS,
TS-E 24 f/3.5 L, 28-135 IS (x2), 50 f/1.8, 85 f/1.8 550EX, 430EX
40mm pancake
the.good.life
Oct 28, 2007 13:18 |  #7
That's a nice picture, IR has a different way of looking at pictures, something like having a different form of art to it.
Where do you have this conversion done, Canon?
johneo wrote in post #4206641 (external link)
TGL
http://www.flickr.com/​photos/dt-photography/ (external link)
Bodies: 50/BP-50, 20D/BG-E2 ... Lenses: bunch of Canons ... Flashes: 380EX, 580EX ...Remotes: RC1, RC-60E3,TC-80N3 ...
johneo
Joined Aug 2003
Oct 28, 2007 14:24 |  #8
the.good.life wrote in post #4206716 (external link)
I had my 10D converted at Lifepixel.com
I went with the deep B&W conversion ... black & white only ... the alternatives are all explained on the website.
I'm finding that it takes a normal color scene and gives it some dramatic looks. This next shot is rather drab in color ... looks pretty cool in IR ... different, anyway :)
http://mysite.verizon.​net/johnori/7909f.jpg (external link)
BTW ... that was shot at 1/45th @ f/11 with the 10D and and the 17-40 L It was resized, I adjusted the contrast slightly and added some sharpening ... very minor editing using Irfanview!
40mm pancake
1,577 views & 0 likes for this thread, 6 members have posted to it.
2812 guests, 135 members online
