Thread started 28 Oct 2007 (Sunday) 12:15
White balance correction
charly
Joined May 2003
Oct 28, 2007 12:15 |  #1
I have the XT and have played w/white balance shift/correction, but haven't really understood what I was doing.
Does anyone use this feature on the XT and do other canon models have the feature? I agree with an earlier topic where the AWB seems to be a typical shooting mode with good results.
Thanks,
charly
Doug ­ Pardee
Oct 29, 2007 11:22 |  #2
WB Shift is pretty much only of interest to JPEG shooters.
I use WB Shift to tweak my Auto White Balance. Left on its own, in daytime conditions (whether sunny, cloudy, or overcast) the AWB will give me pictures that are too cool and a bit too green. After making dozens of test shots, I determined that an A3M3 shift gives me neutral results when using AWB in daytime conditions.
In home incandescent lighting, I use a B6M3 shift along with the Tungsten WB setting to get slightly warm results. A B9M3 shift along with Tungsten WB gives me fairly neutral results, but I generally prefer to keep some of the warmth in indoor shots.
The WB Shift can be used in general to warm up or cool down your images. Some people simply prefer warmer or cooler images, and WB Shift is an easy way to achieve that in JPEG.
Play with it. It doesn't cost anything to take digital test shots. Maybe you'll find some settings that you like.
charly
Joined May 2003
Oct 30, 2007 21:05 as a reply to  @ Doug Pardee's post |  #3
Thanks Doug. I didn't know it was mainly for jpeg (maybe I should rtm).
I'll try your settings and play some more.
Thanks again,
charly
S.Horton
Oct 30, 2007 21:11 |  #4
It deals with the color of light.
Shoot RAW, install Digital Photo Pro, the Canon software, and have a look at what it does to photos by moving the slider around.
Sam - TF Says Ishmael
:cool:
883 views & 0 likes for this thread, 3 members have posted to it.
2890 guests, 137 members online
