Thread started 28 Oct 2007 (Sunday) 18:13
choosing AF points
ps249
Oct 28, 2007 18:13 |  #1
I have the 30D and was wondering if you could choose 3 AF points (I would prefer the 3 horizontal points- far left-center-far right) or can you only choose 1 at a time? (or all 9 at a time as I already know).
Thanks.
40D
50 f/1.8 | 28-135 IS |
MAUREEN SOUZA FOR PRESIDENT!
Yohan ­ Pamudji
Oct 28, 2007 18:21 |  #2
1 at a time only.
xarqi
Oct 28, 2007 18:53 |  #3
Yup - all 9, or any 1. That's it.
Tommy
I have a Peepster.
Oct 28, 2007 18:53 |  #4
Yep... one at a time or all only... What I found that works best is to leave it on center AF point only. Focus, and recompose... but that's not for everyone. ;)
Tommy
"Vision without execution is hallucination" - Thomas Edison (1847-1931)
MySpace (external link)| Facebook (external link) | ModelMayhem (external link) | Blog (external link) | Central PA Wedding and Senior Photographer (external link) | Gear List
JackProton
Oct 28, 2007 22:14 |  #5
The center focus point will give you better accuracy with f2.8 or faster lenses.
Out of curiosity, why are you interested in picking the 3 horizontal focus points?
BogongBreeze
Oct 28, 2007 22:47 |  #6
ps249 wrote in post #4207808 (external link)
Thanks.
The lens focuses on a plane so if you get one item in focus, everything else in the same plane will also be in focus. If you use all 9 points then different points will light up showing what is in the plane of focus. Can be a bit fiddly if you're trying to position yourself to get a row of things in focus, but provided they are in the same plane, the 9 point option will help you achieve this.
I prefer just to judge with my eye and use the focus point nearest to the area I want, but can see there are some situations where using more than one focus point is very useful.
Miriam
Canon 90D and various lenses
ps249
Oct 29, 2007 00:07 |  #7
JackProton wrote in post #4209150 (external link)
it seems to me that those 3 would work best in my photography.
40D
JackProton
Oct 29, 2007 00:12 |  #8
Because you wanted objects at those particular three AF points to all be in focus?
tonylong
...winded
Gallery: 60 photos
Oct 29, 2007 02:29 |  #9
Thanks.
You can only choose either one point or all points. If you choose one point, the camera fixes on one plane of focus, and your aperture setting (as well as distance from your subject and your focal length) determines how much depth-of-field you will have ( how much of your image will appear as sharp). When you choose all focal points, the camera does a best-guess, with an emphasis on the center point, at what the best focal point will be.
Normally, all focal points chosen is an "I don't care" setting, as in they're all infinity or the equivalent relatively, so pick a point, whereas picking a point ensures that one particular plane of focus will be sharp, no matter what the aperture is.
Hope this helps!
Tony
Tony
agedbriar
Oct 29, 2007 05:10 |  #10
I'm using the multicontroller to select the focus point, but I often miss and have to press again to hit the point I want.
Does anyone find the wheel on the back to be the faster way altogether? (CFn-13/2 on the 30D)
BogongBreeze
Oct 29, 2007 05:24 |  #11
I started with the wheel but it was too slow - it just goes through the options one by one. The more I use the jogwheel (multicontroller) the quicker I am. Seems to take a bit of practice. Perhaps it would be easier if the botton was shaped differently - something for the next model?
Miriam
Tommy
I have a Peepster.
Oct 29, 2007 05:58 |  #12
I too use the multi-controller... I'm much quicker with it and can change the AF point without taking my eye out of the viewfinder. ;)
Tommy
bangarang
Oct 29, 2007 08:53 |  #13
Another one here for multi-controller :)
RED Epic-W 8K + Canon Cinema EOS 1DC
agedbriar
Oct 29, 2007 10:21 |  #14
BogongBreeze wrote in post #4210322 (external link)
I agree, Miriam.
A larger multicontroller top surface would make choosing the right direction easier.
Jon
Joined Jun 2004
Oct 29, 2007 12:02 |  #15
Multicontroller joystick all the way.
Jon
Cocker Spaniels
1,757 views & 0 likes for this thread, 10 members have posted to it.
choosing AF points
2766 guests, 140 members online
