I'm looking to put a Powerpoint presentation together on the principles of composition. I'd like to be able to show an image and then overlay a "rule of thirds" grid over the image.
Any idea how I can do that?
Oct 28, 2007 20:13 | #1 I'm looking to put a Powerpoint presentation together on the principles of composition. I'd like to be able to show an image and then overlay a "rule of thirds" grid over the image. My Gear
Radtech1 Everlasting Gobstopper 6,455 posts Likes: 38 Joined Jun 2003 Location: Trantor More info | Oct 28, 2007 20:24 | #2 Well, the simple answer would be a second slide of the same shot, this one with the overlay PSed in. Now that wouldn't give your audience any sort of fancy animation (that is, the overlay would not fly in and settle down on the shot) but it would be the easiest way to make the point. .
And what would be your idea for PSing the overlay? My Gear
Radtech1 Everlasting Gobstopper 6,455 posts Likes: 38 Joined Jun 2003 Location: Trantor More info | Oct 28, 2007 20:39 | #4 nicshow wrote in post #4208581 And what would be your idea for PSing the overlay? Danny's 3x3 Action at http://www.atncentral.com/download.htm .
Can that action be used in PSE5? My Gear
Lyssi Senior Member 439 posts Likes: 2 Joined Mar 2006 Location: NW Ontario, Canada More info | This might be too simple a solution for you, but you can easily make a grid in PS Elements.
Radtech1 Everlasting Gobstopper 6,455 posts Likes: 38 Joined Jun 2003 Location: Trantor More info | Oct 28, 2007 23:20 | #7 OK, I see the problem. .
I understand pibb's idea but when I went to draw the line, it keeps giving me some rectangle or box shape - even though I AM clicking on the "line" tool. My Gear
Lyssi Senior Member 439 posts Likes: 2 Joined Mar 2006 Location: NW Ontario, Canada More info | Hi,
Lyssi Senior Member 439 posts Likes: 2 Joined Mar 2006 Location: NW Ontario, Canada More info | I think what is happening is that the default "weight" or size of the pen is so small that you cannot see the line. It's there. (I thought it was gone too until I magnified the canvas and could then see the very thin line, 1 px)
Radtech1 Everlasting Gobstopper 6,455 posts Likes: 38 Joined Jun 2003 Location: Trantor More info | Oct 28, 2007 23:58 | #11 nicshow wrote in post #4209445 I understand pibb's idea but when I went to draw the line, it keeps giving me some rectangle or box shape - even though I AM clicking on the "line" tool. At first I got one line drawn but when I went to make the 2nd line, the first went away so I'm assuming each line will have to be in its own layer? And then flatten all the layers to have a transparent image with a grid on it?
Radtech1 wrote in post #4209389 To get the pencil to draw a straight line, click (once) the pencil where you want the line to start, then move the pencil to where you want the line to end, press and hold the <SHIFT> key, then click the pencil again. That just made a straight line from the first to the second point. Rad .
Lyssi Senior Member 439 posts Likes: 2 Joined Mar 2006 Location: NW Ontario, Canada More info | Rad,
Lyssi Senior Member 439 posts Likes: 2 Joined Mar 2006 Location: NW Ontario, Canada More info | Nic,
milleker Goldmember 1,851 posts Joined Feb 2006 Location: Baltimore, Maryland More info | Oct 29, 2007 08:19 | #14 Why not show rulers, set them to percentage and hand-draw lines at 33 and 66%. Doesn't need to be exact, heck - eyeballing it would work fine in such an instance. ---John Milleker Jr.--
davidlee Senior Member 586 posts Likes: 1 Joined Sep 2005 Location: Kent, England More info | Oct 29, 2007 18:08 | #15 milleker wrote in post #4210841 Why not show rulers, set them to percentage and hand-draw lines at 33 and 66%. Doesn't need to be exact, heck - eyeballing it would work fine in such an instance.
davidleeimages.co.uk
| Latest registered member is semonsters 1036 guests, 107 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
