Thread started 29 Oct 2007 (Monday) 07:28
Saturday's Wedding (assistant/2ndshooter)
Echo63
Oct 29, 2007 07:28 |  #1
I helped a friend out as an assistant/second shooter on saturday, and have sorted out a few photos to ask you all for your comments on
i normally shoot motorsport, but this was a change from fast cars, and i enjoyed it.
these are all pretty much straight out of the camera, just cropped/resized to 640x480px - #2 had a slight levels adjustment as it was a little dark
all photos shot with 1dmk2n and 580EX , and either sigma 10-20mm, 24-70 f2.8 and 70-200 f2.8 lenses - Exif should still be available on all of them
1
2
3
4
5
6
7
8 this is the pageboy and flowergirl, laying on the dancefloor at the reception - i know its a little yellow, i need to get some tungsten gel for my flash so i can use the tungsten WB and have everything look right
any comments or advice are welcome, this was the first paid wedding i have assisted with, and want to learn
My Best Imageswww.echo63.deviantart.​com (external link)
Gear listhttps://photography-on-the.net …p?p=2463426&pos​tcount=385
KennethPhotography
Oct 29, 2007 17:36 |  #2
The photos are sharp! :)
It looks like the couple was posing for the primary photog and you were shooting from another vantage point so to me some of these feel "off" because of it.
I don't know if it was lens choice limited but I'd like to see less DOF, especially on #5. I think it could also be improved with different composition (again, not sure if you were forced off to the side while the primary got all the "good" vantage points) but if you had used less DOF the windows would be less distracting.
Can you use less flash outdoors? It seems a bit overpowering, again obvious in #5 with the reflections and it really lit the column and in 6 it really reflected off the door. You've got fast glass, use it. :P
Echo63
Oct 29, 2007 21:41 |  #3
KennethPhotography wrote in post #4213918 (external link)
thanks
yep, most of them the couple were looking at the other photographer
Lens choice wasnt limited at all, i had all my lenses with me, and the main shooter used his gear.
#5 was shot with the sigma 10-20- which tends to have a huge DOF even wide open, that is why i used the flash, to try and drop the exposure on the windows a bit more so they werent so distracting
i can see what you mean with #6, the reflection looks pretty poor
#5 the only flash reflection is the white spot on the window frame, the reflection in the glass is the open area behind me - but i see what you mean about the reflections, it is annoying
thanks for the advice, next time i help with a wedding i will try your advice
MrsOpie
Oct 29, 2007 23:58 |  #4
I think these need a little extra pop with some processing in photoshop. Otherwise the shots are ok, the exposures are ok, but its hard to get a connection with the couple since they aren't looking at the camera.
-OpieFoto
Salt Lake City Utah Wedding Photographer (external link)
Modern, Bold, Raw Emotion
bnlearle
Oct 30, 2007 00:08 |  #5
I agree with Mrs. Opie
twitter (external link) // facebook (external link)
Website (external link)
San Diego Wedding Photographer blog (external link)
Echo63
Oct 30, 2007 00:59 |  #6
MrsOpie wrote in post #4216158 (external link)
i will agree with you there, i normally shoot raw, but the person i was assisting asked me to shoot Large Jpeg, so these are shot with my normal in camera settings. i will have a go with photoshop to get the "pop" and repost them here
PS wont get the connection with the couple though
KennethPhotography
Oct 30, 2007 10:53 |  #7
Echo63 wrote in post #4215396 (external link)
thanks
I was suggesting that perhaps your DOF was limited BY lens choice (which clearly it was in #5) not that your lens choices were limited. IMHO you probably could have picked a different lens that would have given you more creative control (especially over DOF). As you aptly pointed out an ULTRA wide lens is going to limit your Bokeh (unless it's a f/1.4 and your subject distance is close).
I like a slightly longer lens for portrait work to make people "pop" out of the surroundings.
As you know, this is the internet so take anything I say for a grain of salt. I'm not even happy enough with my photos to post them up. ;)
Echo63
Oct 31, 2007 02:52 as a reply to  @ KennethPhotography's post |  #8
ok i have had a little play in lightroom, and these two seem to "pop" a bit more now (more contrast, colour and a slight exposure correction)
and this one i had a play with in lightroom, tried to darken the background a little more, then added some blur to the background with photoshop
Wedding ­ Shooter
Oct 31, 2007 07:35 |  #9
Nice to see some shots of Perth in there Echo.
Chris
Echo63
Oct 31, 2007 13:12 |  #10
Wedding Shooter wrote in post #4224474 (external link)
thanks, first time i have assisted with a wedding, not the greatest shots in the world, but i think i did pretty well, i do need to pay attention to a few more things, as the people above me have suggested.
2,235 views & 0 likes for this thread, 5 members have posted to it.
1010 guests, 110 members online
