Thread started 29 Oct 2007 (Monday) 21:19
Parade Pictures what to bring equipment wise
SOT
I make up stuff about Cameras
Oct 29, 2007 21:19 |  #1
Please consider the following equipment list. I would prefer to bring ONE maybe two cameras as I will be moving all day along the route and this is for my personal pictures, not some paying thing. Weather looks to be good and sunny. Temps in the mid 50's. All shooting is outside.
It's the Red Sox parade in Boston...if that helps
Bodies:
30D with grip
40D with grip
5D with grip
1D Mk II
Lenses:
Canon EF 16-35mm f/2.8L USM
Canon EF 17-40mm f/4L USM
Canon EF 20-35mm f/3.5-4.5 USM
Canon EF 50mm f/1.4 USM
Canon EF 85mm f/1.2L II USM
Canon EF-S 17-55 f/2.8 IS USM
Canon EF 28-300mm f/3.5-5.6L IS USM
Canon EF 28-135mm f/3.5-5.6 IS USM
Canon EF 24-105mm f/4L IS USM
Canon EF 70-200mm f/2.8L IS USM
Canon EF 100-400mm f/4.5-5.6L IS USM
Canon EF 400mm f/2.8L IS USM
Cards and batteries are covered. Not sure about a flash.
I will have good position on all the route from about 10 meters to "infinity" off the line.
I was sort of thinking the 40D as it's my new "toy" and I like it a lot or the or MkII with the EF 28-300mm f/3.5-5.6L IS USM lens.
http://img81.imageshac​k.us/img81/8646/captur​e1o.jpg (external link)
jonathon
Oct 29, 2007 21:23 |  #2
I covered Gasparilla in Tampa with a 30D and 70-200 2.8 IS and it worked out pretty well. A UWA would have been helpful, but I didn't want to bring two bodies and didn't want to change lenses on the route.
http://www.jwilliampho​to.com/p653326655/ (external link) <-- Gasparilla pics
Bodies, Lenses, bla bla bla[/SIZE]
modemanual
Oct 29, 2007 21:24 |  #3
For me, id take at least 2-3 bodies, one with a 17-40, one with a 85mm, and one that covers the telephoto range.
HULKMA.
40D (sooon!) | 50 1,8 | 70-200 2,8L Lens Coated | Speedlite 580EX II | Crumpler 7MDH
gear - smugmug (external link) - lurkbook (external link)
Tapeman
Sliced Bread
Joined Jan 2004
Oct 29, 2007 21:46 |  #4
I'd take the 5D with the 24-105 and the 1D MKII with the70-200. Lots of range no lens changing. Have fun!
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
Mark_Cohran
Joined Jul 2002
Oct 29, 2007 22:47 |  #5
Tapeman wrote in post #4215418 (external link)
That's essentially what I used for the last parade I shot (in July) and I was very pleased with the results.
Mark
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
SOT
Oct 30, 2007 00:17 |  #6
thanks guys...I guess two it is.
ItsMike
Oct 30, 2007 00:52 |  #7
SOT wrote in post #4215269 (external link)
Bodies:
30D with grip
40D with grip
5D with grip
1D Mk II
Lenses:
With a gear list like that and you are asking what to bring? One would assume that you would have the experience and knowledge of you gear that you would know what to bring..
Gear
Lightstream
Yoda
Joined Feb 2006
Oct 30, 2007 02:14 |  #8
I'd bring the 5D and 24-105, I have done it before at parades. Also got good spots near the front, and that lens provides a good mix of wide angle (which I use a lot) and telephoto.
I attended one other similar event with a 1D/70-200, found it wasn't wide enough for a lot of situations, but I still found its telephoto reach useful. So you might want to consider bringing that..
Maybe mount the 70-200 on the 40D and the 24-105 on the 5D. That way you are covered continuously from 24mm to 320mm (FOV equivalent)
tonylong
...winded
Gallery: 60 photos
Oct 30, 2007 02:36 |  #9
I'm dying to crack a joke, because, as many have said, you have so much...stuff. Why do you need our advice?
OK, so jokes aside: what do you need?
A 5D with a 16-35L will get your wide shots.
A 24-105L will get most of your shots.
A 70-200 L will get the rest of your shots.
The rest is up to you, given your very narrow range of equipment:)!
Tony
Tony
MegaTron
Joined Jun 2005
Oct 30, 2007 02:57 |  #10
If I wasnt getting paid, id take the 5D + 28-300L. Should be plenty wide, and you should have enough reach for the majority of your shots.
ccp900
Oct 30, 2007 05:22 |  #11
dude, 5d and 28-300 L...i dont think youd miss a shot. i fyou wanna go lighter then just the 5d and 24-105L.
i shot a parade in London, Lord Mayor's show just with my 30D and 24-105L
[Sony A7R Mark 3 | Sony A7S | Sony Zeiss 16-35m f/4.0 | Sony FE 85m f1.8 | Sony FE 20m f1.8 G | Samyang 18m f2.8 | Samyang 45m f1.8 | Zeiss Batis 40m f2 | Sony FE 28m f2 | Sony Zeiss 55m f1.8 | Sony FE 28-70m f/3.5-5.6 | Helios 44-2 | Helios 44-3 | Nikon 105m f/2.5 AIS | Contax Zeiss Planar 50m f1.7 | Contax Zeiss Planar 100m f2 | Voigtlander Nokton 40m f/1.4 | Canon 24-105m f/4.0L | Canon 85m f/1.8 | Sigma 30m f/1.4 | Canon 10-22m f/3.5-4.5 | Canon 100m f/2.8 Macro USM | Canon 580 EX Ver 1.0]
MaDProFF
Oct 30, 2007 05:42 |  #12
if you want to take 2 bodies, 40D 70-200mm, 5D 24-105mm
Though I never used a 5D, or a 28-300L but chances are that would get you everything, but miss some nice shallow DOF
Photographic Images on Brett Butler (external link) px500 (external link) & Flickr (external link) Some Canon Bodies , few blackish lenses, A dam heavy black one, couple dirty white ones, a 3 legged walking stick, a mono walking stick, and a bag full of rubbish :oops:
And Still Learning all walks of life, & most of all Photography.
LotsToLearn
Oct 30, 2007 06:54 |  #13
I regularly shoot street fests with my 70-200 and 17-40. I find that as long as you're easily mobile then you shouldn't have much difficulty getting the shots you want regardless of the body sensor size and to a degree, lens choice.
jmann12180
Gallery: 11 photos
Oct 30, 2007 07:40 |  #14
I'd bring the camera body with Yankee pin strips.
- George ;)
Canon 7D | EF 50mm f/1.8 | EF-S 18-55mm f/3.5-5.6 | Tamron 17-50 f/2.8 | EF 70-200mm f/4 L USM | EF-S 55-250 f4-5.6 IS | Sigma 10-20mm | Kenko Extension Tubes | 430EX Speedlite E-TTL II
stathunter
"I am no one really"
Oct 30, 2007 08:33 |  #15
Sell one of your lenses and purchase a book on how to photograph parades! :)
Scott
"Do or do not, there is no try"
2,369 views & 0 likes for this thread, 15 members have posted to it.
2839 guests, 133 members online
