Cyth0n wrote in post #4224182
Why would you want to keep a 14 bit image then? Because some expensive/commercial printers are capable of printing a higher range of colours than 8bit.
Not really that relevent, the human eye cannot see much more than an 8 bit image so having a device output more detail is irrelevent. To prove it try loading up your favorite photo ed package and creating a 2 pixel image which you zoom in to max. Set one pixel to the value 255,255,255 and set the other one to 254,254,254.
Assuming a decent monitor/colour space you will not be able to see the difference between the 2 pixels, it will just look like a uniform white rectangle.
However do the same with 255,255,255 and 253,253,253 and you may see a very slight difference down to 252 and you should definately see one, so we know that is the difference the eye can pick up.
The reason why you would want more so much more than 8 bit has nothing to do with trying to reproduce it accurately and everything to do with being able to process the data.
Say for instance you wanted to increase the brightness and contrast so you multiple every colour value by 4. If you do this to your original image then you will now have a step of 4 between 2 almost similar values which we already know is visible to the human eye (posterisation).
If however you already have values which only differ by a quarter of what the human eye can differentiate you can multiple by 4 without introducing any visible steps, the more "invisible" detail you have the more processing you can do.
THAT is the reason for wanting more bits, it has nothing to do with being a more accurate photograph of the object.
NOTE: I have left noise out of the situation for the sake of simplicity
