Thread started 01 Nov 2007 (Thursday) 17:51
Can Sigma 500 DG Super be a wireless master?
dr_who
Nov 01, 2007 17:51 |  #1
Does the 500 DG have a wireless transmitter built-in? Is there any (cheap) receiver I can buy to trigger off my Sunpak flashes thru their hotshoe? The Will the cactus v1/v2 work?
Thank you for your help. I'm kind of new to flash and don't want to waste my $$$ on things I will not work.
5D, 50mm F1.4, Sigma 24-70, EF 70-200mm F2.8 IS
kevie
Nov 01, 2007 19:12 |  #2
There are also optical slaves that fit on the hotshoe of the sunpak flash that arent too expensive....
30D - 70-200mm f4 L + 17-40mm f4 L + 50mm f1.8 + 2x Sigma 530 super + Kata R-103
www.viraltheshow.com (external link)
dr_who
Nov 01, 2007 19:41 |  #3
kevie wrote in post #4235302 (external link)
I have a optical slave trigger. The only problem is it's triggered by the pre-flash...
kevie
Nov 01, 2007 20:01 |  #4
Not sure but i think there is some function you have to enable/disable so you dont get the preflash.(or maybe its switching it to manual mode cant remember where i read it)
hard12find
Nov 01, 2007 20:06 |  #5
you can download the manual for the super from Sigma's website as a PDF, and yes it can be set for master or slave.
Jim
20D, 10D, Fuji S-20, Mamiya C220 medium format, Sekonic L-508 meter, 2 alien bee 800's, AB remotes, Sigma 500 HS flash, 70-200 F2.8 L, Sigma 24-70 F2.8 EX DG, lots of glass, lots of stuff,8-)
FlashZebra
This space available
Nov 02, 2007 00:01 |  #6
dr_who wrote in post #4234856 (external link)
What Sunpak flash units do you have? Sort of hard to suggest a setup without knowing exactly what gear you have.
Enjoy! Lon
quientus
Nov 02, 2007 06:44 |  #7
dr_who wrote in post #4235500 (external link)
Set your main flash to 1/128 power on manual.
Curtis ­ N
Master Flasher
Nov 02, 2007 08:48 |  #8
The Sigma EF-500 DG Super has E-TTL wireless master capability, but...
1) It's only designed to work with other Sigma Supers or Canon EX flash units with E-TTL slave capability.
2) It doesn't work very well, in my experience.
However, if the Sunpak you mention is a regular old automatic/manual flash unit such as their 383 model, then it can be used as a slave by attaching an inexpensive optical slave sensor.
Any flash unit can be a "master" to optical slaves, as long as the master is not in E-TTL mode. Your Sigma Super, in manual mode, can be a master.
What's more, the Sigma Super has an optical slave sensor built-in. So it can be the slave while the Sunpak plays the role of master. Because of this capability, the Sigma Super and Sunpak 383 plus slave attachment are a wonderfully versatile combination. Both units are in my bag at all times.
1,803 views & 0 likes for this thread, 6 members have posted to it.
1019 guests, 122 members online
