Thread started 01 Nov 2007 (Thursday) 18:11
dpreview review
Cr4zYH3aD
Nov 01, 2007 18:11 |  #1
dpreview.com posted a review of the 40D! Looks really nice compared to the 400D :(
Well, i guess a 18-55 IS is all I can afford. I don't know how much the IS is reliable..does it push the anti-shake really far?
Say that a basic 10-55 is blurry at 1/50, can the IS system be free of any blur at 1 sec ?
Canon EOS 7D | Canon EF 100mm f/2.8L Macro IS USM
lederK
Nov 01, 2007 18:31 |  #2
Cr4zYH3aD wrote in post #4234944 (external link)
No. to take your example, a picture without IS at 1/50 will be equally blurry as a picture taken with IS at shuttertimes of:
1/50 without IS
1/25 at one stop effective IS
1/12 at two --- " ---
1/6 at thee --- " ---
1/3 at four --- " ---
In general multiply your non-IS shutter time by 2^n (2 to the power of n), where n is the effective number of stops of the IS, to get the shutter time you can pull with IS.
I don't know how good the IS of the 18-55 is, but I would be highly surprised if it was above 3 stops (real world stops, not the marketing kind)
/lk
Got : 350D, 17-85 IS , nifty, Sigma 10-20, 70-200 f4L, 70-200 IS f4L, 430EX, SB-24, tripods and stuff...
Want : Photographic talent and skill
Cr4zYH3aD
Nov 01, 2007 20:02 |  #3
well, IS, worth it ? .. Maybe not
Hermeto
Nov 01, 2007 20:14 |  #4
Cr4zYH3aD wrote in post #4235632 (external link)
Until you miss a really important shot you’ll not know the answer to that question, I’m afraid.. ;)
Cr4zYH3aD
Nov 01, 2007 20:22 |  #5
hehe.. im just tired of blurry picture when there's just not enough light. I wanted IS to give me clear shot like when the camera is on a tripod.
Hermeto
Nov 01, 2007 20:31 |  #6
Pictures can be blurry for two different reasons: Camera motion blur and Subject moving blur.
Image Stabilization lenses will help you only with the former.
High shutter speed will take care about the later.
Cr4zYH3aD
Nov 02, 2007 00:48 |  #7
I know !
Im trying to lessen the former.
cy88
Nov 02, 2007 00:57 |  #8
I would say, skip the 18-55IS, save up more and go for the 17-55IS. It's a long way there, but it'll be worth it. In that case, the F2.8 and the IS will help with movement and camera motion blur.
6D | 5D2 | 24L II | 35L | 85L II | 100L | Panasonic GX7 | Olympus 12/2.0 | Panasonic 20/1.7
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Nov 02, 2007 01:47 as a reply to  @ Cr4zYH3aD's post |  #9
Without the need to whip out your slide rule (calculator, if you are a youngster), a rough rule of thumb for Canon IS systems is an improvement of 2 EV in shutter speed compared to not using image stabilization. If you are shooting hand held indoor exposures, then your results will still not be up to the quality of using a tripod.
In addition to the description of motion blur given above by Hermeto, hand held motion can further be broken down into two components: low amplitude oscillatory motion (shake) and steady state drift motion which changes direction much slower than shake.
Image stabilization handles the first component well, but cannot effectively help steady state or very low frequency drift. Do a self examination of your ability to stay on target by aiming a long lens at a clearly discernible distant object using your normal holding technique. It is easy to determine your shaking motion. But, examine how well you are keeping the camera aimed at a fixed location.
Fire off several shots while trying to keep the camera steady. Examine the results for motion blur due to shake -- the amount of blur with IS active will be roughly 1/4th as much assuming every thing else remains the same. Now compare all of the shots to see if you have a drift problem. If you tend to drift significantly, the results will not be helped by IS.
Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
Gear List .... Gallery: Woodturner Bill (external link)
Donate to Support POTN Operating Costs
PompeyJohn
Location: Portsmouth England, South Coast home of Royal Navy.
Nov 02, 2007 02:02 |  #10
In my humble opinion i could not be without IS now. All my cameras now have it and it is a god send. I have lost count now on the times it has helped me out and allowed me to get shots i had no right to get. It of course isnt perfect but what in life is (well my wife is just in case she reads this one).
I have just got myself the 40D with 17-85 IS Lens. The lens is great and camera is outstanding.
EOS 40D + 17-85mm IS USM.
timbop
Nov 02, 2007 06:26 |  #11
Cr4zYH3aD wrote in post #4235786 (external link)
OK, so then your initial example might not be helped much by IS - i assume you are familiar with the 1/fl (or 1/fl*1.6) rule. If the shot is blurry at 1/50 and 18mm, the problem is not camera shake but subject motion. At 100mm, then yes IS would definitely help. Honestly, a cheaper and better way to deal with poor lighting at short focal lengths is external flash with diffuser - much better than the popup flash. Flash will freeze motion and allow higher shutter speeds to compensate for shake; properly bouncing or diffusing it can help preserve the "mood" of the setting. Alternatively, adding something like the 50/1.8 can also do the job.
Current: 5DM3, 6D, 8mm fish, 24-105/4IS, 35/2IS, 70-200/2.8IS, 85/1.8, 100-400/IS v1, lensbaby composer with edge 80, 580's and AB800's
Formerly: 80D, 7D, 300D, 5D, 5DM2, 20D, 50D, 1DM2, 17-55IS, 24-70/2.8, 28-135IS, 40/2.8, 50/1.8, 50/1.4, 70-200/4IS, 70-300IS, 70-200/2.8, 100 macro, 400/5.6, tammy 17-50 and 28-75, sigma 50 macro & 100-300
spsmith
Nov 02, 2007 09:05 as a reply to  @ Cr4zYH3aD's post |  #12
IS has really helped me with focus precision (I'm not very steady). Quite often I find myself trying to focus on one relatively small object (ie: a single leaf in a mass of branches, a childs eye...) Using the center focus point, IS helps me keep the point on the correct subject.
Shaun
1D3 | 1D2n | 17-40 | 35 1.4 | 85 1.8 | 100
2.8 Macro | 70-200 2.8 IS | 400 2.8 IS | 430ex | 580exii |
"For every opinion, there is an equal and opposite opinion"...so take mine with a grain of salt!
Mark_Cohran
Joined Jul 2002
Nov 02, 2007 09:15 |  #13
I like IS, but it's not a miracle cure. I've taken some pretty nice shots down to 1/8th of a second using my 24-105 f/4L IS - but that was on a full frame 5D at 24mm. 1 second would be really pushing it, even with that combo.
Mark
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
fashioneyes
Nov 02, 2007 09:17 |  #14
With IS you'll find your can hand hold much slower with reasonable results. Like others have said there's no substitute for tripod.
I've held 1/10th on a 24mm setting and got a good shot.
1D4, 7D, 5D2 + L lenses
Links: Jepson Photography (external link) / Model Portfolio (external link)
A-Plant BSB Team (external link)
Cr4zYH3aD
Nov 03, 2007 18:15 |  #15
ok I guess 40D would be the perfect camera if it would have been Full frame.
Anyway, Thanks. I dont want a flash, it kills the atmosphere when you take pictures outside. Always carrying a tripod is troublesome. I thought IS was much better !
4,071 views & 0 likes for this thread, 10 members have posted to it.
dpreview review
2924 guests, 140 members online
