Hi All,
I have been using a 550EX, 30D, and 17-85mm EFs lens. Many of my indoor flash shots show light fall off, almost like vignetting, in the corners. If I take the same pictures without my flash (using a high ISO), the light fall off is mimimal.
I shot these two pictures of a wall from about 7 feet away. Is this a flash problem, or is it something else?
Thanks,
Dom
![]() | HTTP response: 404 | MIME changed to 'image/gif' | Byte size: ZERO | PHOTOBUCKET ERROR IMAGE |
1/60th @ f4.0; 17mm, 17-85mm EFs, 550EX, wall 7 feet away. Lens hood removed.
1/60th @ f5.6; 85mm, 17-85mm EFs, 550EX, wall 7 feet away. Lens hood removed.
Yep, I see the dust spot on the sensor!
