Thread started 01 Nov 2007 (Thursday) 19:08
20D: Manual Mode in Low Light - Question
Mike-DT6
Nov 01, 2007 19:08 |  #1
EDIT: Unfortunately all my original image links are now broken. My photographs are now hosted at Flickr and on my website. Links to both of these sites are in my signature section.
Apologies for any broken image links that are now showing in any of my threads or posts.
Thanks,
Mike
Gear list
Mike-DT6
Nov 01, 2007 19:08 |  #2
Thanks,
Mike
Gear list
Sickness
Nov 01, 2007 19:14 |  #3
Try switching it to manual focus. Focus on the torch, switch AF to off, then snap a picture. You could also up the ISO to achieve a shorter shutter speed, I believe. Crank that up to H.
Canon 20D
Canon 28-80 f/3.5-5.6 MK1 /
Zeiss 50mm f/1.7
Sigma 20mm f/1.8 / Canon 28-135 IS
Jim ­ G
I feel thoroughly satisfied
Joined Jun 2005
Nov 01, 2007 19:14 |  #4
If the lens won't autofocus just switch it to manual focus!
One way around this is to set custom function 4 to 1 - that way focus will be your rear * button and exposure lock the shutter button.... separating those two was a huge advantage for me and makes what I do far, far easier! That way you can pre-focus with the * button, turn the light off then snap away as you please without interfering with focus.
Gear Listhttp://www.codastudios​.com.au (external link) Reviews & Hotlinks: Domke F-3x - Pelican 1510/1514 (external link) & 1610/1614 (external link) - DIY Variable Length OC-E3 - Crumpler 6 Million Dollar Home (external link) - FA-100 (external link)
Mike-DT6
Nov 01, 2007 19:15 |  #5
Thanks,
Mike
Gear list
Mike-DT6
Nov 01, 2007 19:17 |  #6
Thanks,
Mike
Gear list
number ­ six
fully entitled to be jealous
Nov 01, 2007 20:14 |  #7
BTW, Mike, you need to account for the fact that the lens will focus beyond infinity if you're setting focus manually.
A good approach would be to manually focus to infinity in daylight, when you can see through the viewfinder, and mark the focus point on the lens body for future use at night.
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
Mike-DT6
Nov 01, 2007 21:11 |  #8
Thanks,
Mike
Gear list
885 views & 0 likes for this thread, 4 members have posted to it.
2936 guests, 140 members online
