Thread started 02 Nov 2007 (Friday) 05:10
Exposure Compensation Problem on 30D
bobinatcat
Nov 02, 2007 05:10 |  #1
I just noticed when I change the exposure compensation to say -2 when the shutter button or the metering/exposure button is pressed it goes back to +/- 0...didn't think much of that until I start seeing everything was blown out and when i checked the Exif on the pics everything was still +/- 0.
The odd thing is with my 550ex attached the flash compensation registered correctly yet the body e.c. didnt.
Am I missing anything here? Trouble is I can't consult my instruction book because I'm not in my home country :D
Thanks,
Matt
30D - Sigma 17-70 - 550ex
AJ05
Nov 02, 2007 10:02 |  #2
Which "on" position do you have the camera on when you make the exposure compensation adjustments? I don't have my 30D in front of me now, but I believe you have to have the on switch set on the second "on" position - the one that looks like a line (/) leading to the dial.
~Alice~
GEAR LIST —> https://photography-on-the.net …?p=6507554&post​count=1416https://photography-on-the.net/forum/showthre​ad.php?t=580379
Lowner
"I'm the original idiot"
Nov 02, 2007 10:24 |  #3
Alice,
Your are exactly right, in fact I cannot make exposure compensation adjustments any other way. Using the "main control dial" on mine moves the shutter (or aperture) but will not alter the EV value of the shot.
Richard
Richard
AJ05
Nov 02, 2007 10:39 |  #4
Richard - thanks for confirming that.
~Alice~
bobinatcat
Nov 02, 2007 13:07 |  #5
Ah yes, even with it switched to the second dial setting. But like it said, the diagram indicates it has moved plus or minus in the e.c. but when the picture is taken it does not take the e.c. into account.
Grentz
Nov 02, 2007 14:05 |  #6
Do you see the compensation go back to 0 or does it just seem like it from the pics? Very odd either way...
Search.TechIslands.com (external link) - Photography Shopping Search Engine
www.TechIslands.com (external link) - News and Reviews
My Gear List - 60D
Doug ­ Pardee
Nov 02, 2007 15:27 |  #7
In the category of "make sure it's plugged in":
A number of people get confused and adjust the flash exposure compensation instead of EC. Do not press any buttons on the top of the camera. Have the power switch turned to the line past "on", half-press the shutter, and spin the rear dial. Repeat: do not press the "lightning bolt +/-" button on the top of the camera. That's FEC, not EC. The lightning bolt means "flash". The button for normal EC is the shutter button (half-press).
bobinatcat
Nov 02, 2007 17:12 |  #8
Doug Pardee wrote in post #4240500 (external link)
Thanks, that did the trick. Is the FEC on the camera any different to the one on the physical 550ex unit...or just a shortcut to the 550ex controls. Or does it just adjust the inbuilt flash controls?
SeanH
Nov 02, 2007 17:29 as a reply to  @ bobinatcat's post |  #9
FEC.......bingo.
Not Camera EC
7D ......waiting on the 5D3
10-22, 17-40 4.0 L, 24-70 2.8L, 70-200 2.8L, 2 X 580EX's
1,053 views & 0 likes for this thread, 6 members have posted to it.
2924 guests, 140 members online
