Thread started 02 Nov 2007 (Friday) 18:44
Upgraded from a 20D to a 40D - VERY Dissapointed.
crobs808
Nov 02, 2007 18:44 |  #1
I do not understand...all my photos with my 20D were sharp and I was just using the cheap kit lens (28-135 IS), now I have a 40D and a $1,000 lens, then 24-70L and my images are soft in the middle and all over for that matter. I always use the center AF point when shooting...whats going on? here are some unedited center crops from the middle of a few photos.
1/125 @ 2.8, ISO 800
1/125 @ 2.8, ISO 400
is this a front/back focus issue or what? can i send it in to be fixed? what number do i call, does canon charge? i've had a 20D for two years, and a Canon XL1 for over 5 years and never had to send in anything, so not sure what to do. Any guidance is appreicated! :rolleyes:
Thanks,
::: Connor
5DII | 28-135mm IS USM | 50mm II | HVX200
No trees were harmed in the creation of this post; however, a large number of electrons were terribly inconvenienced.
jra
Nov 02, 2007 18:47 |  #2
Have you tried your old lens on the 40D? You may want to do a more controled test with a better subject such as a focus chart or some batteries. Make sure you are using a tripod and remote release (or timer release) also MLU is a good idea to help eliminate any camera shake.
In the second pic, the bolt does not appear in focus but that would be a difficult situation for the camera's auto focus to know exactly where you were focusing....It looks like it focused on the area of contrast in front of the bold
crobs808
Nov 02, 2007 19:01 |  #3
jra wrote in post #4241468 (external link)
but i used center AF point, put it right on where the top of the bolt meets the side of the bolt.
no, i havent tried my old lens, because i sold it with my 20D to get money to buy the 40D.
::: connor
dmwphoto
Nov 02, 2007 19:05 |  #4
The problem is not the camera but the lens. Try it at f4
Dave Watts
dmwphoto.smugmug.com (external link)
jra
Nov 02, 2007 19:06 |  #5
crobs808 wrote in post #4241544 (external link)
::: connor
Keep in mind that the autofocus sensors are somewhat larger than the indicators we see in the viewfinder. When multiple areas of contrast are covered by the sensor, you may not get exactly what you wanted. In a situation where the areas of contrast are located very close together, as in your second photo, it's almost impossible to tell in the viewfinder if you nailed the focus exactly as you wanted it. Also, were you handholding these shots? Small body movements as you breath and keep your balance while using a large aperture can and will move your focus point.
jra
Nov 02, 2007 19:09 |  #6
dmwphoto wrote in post #4241568 (external link)
I agree, the 24-70 really sharpens up when stopped down a stop or two but I think he should be getting better results at f2.8. Larger apertures can be a bit tougher to work with because a slightly missed focus will really show up due to the narrow DOF.
crobs808
Nov 02, 2007 19:34 |  #7
OH - I also have the image mode thing on Faithful, 0,0,0,0, since I figured all editing should be done in post...am I wrong, should I change it back to the default that was 3,0,0,0 i think? which is the best to put it on? I think it is dumb they added that feature.
::: connor
lungdoc
Nov 02, 2007 19:42 |  #8
Well you are going to need to get a bit scientific to try to narrow things down. Time to try to see where the problem is - I'd start with using tripod and remote release or timer. Try your Sigma 30 at 2.8 and 4 versus your Canon lens at 30mm 2.8 and 4. Try a focus test chart (do a quick search to find links to them) from 45 degree angle; failing that line up some AA batteries about an inch apart each. I'd put setting at standard if you're using jpg just to keep it consistent with how you used your 20D. Try manual focus also to see if any difference.
Mark
My Smugmug (external link) Eos 7D, Canon G1X II, Canon 15-85 IS, Canon 17-85 IS, Sigma 100-300 EX IF HSM, Canon 50mm 1.8, Canon 85mm 1.8, Canon 100mm 2.8 Macro, Sigma 50-150 2.8, Sigma 1.4 EX DG , Sigma 24-70 F2.8 DG Macro, Canon EF-S 10-22, Canon 430EX,
eveningSight
Nov 02, 2007 20:00 as a reply to  @ lungdoc's post |  #9
It seems that the two pics were shot in dim light situation, and the problem is "blur" not focus. Try to use tripod in this case and remote release. 2 pics are not enough to judge..
MCB
Joined Jun 2005
Nov 02, 2007 20:13 |  #10
eveningSight wrote in post #4241861 (external link)
That's a good point. It doesn't really look like front or back focusing. From the first picture, it looks like the bolt is in the DOF. But in the cropped image, nothing is really sharp. It doesn't look like there is some other area that is in better focus (like in front of or behind the bolt). The whole image is just soft, not focused on the wrong spot.
That could still be the camera, though, but maybe a tripod and better lighting could give better results.
Good luck.
[edit: then again, at 1/125 you would need a pretty shaky hand to get that much blur... were you standing on your head?? :)]
Stephen ­ Scharf
Nov 02, 2007 20:14 |  #11
I doubt it is the lens or motion blur, as you could see it even in the "overview shots, the sides of tree trunk and bolt would be blurred.
and:
Agreed. The whole image is soft in both shots. I doubt it is the lens, too, as 24-70 should be tack sharp in the center, even at f/2.8, and even at this shutter speed.
Stephen J Scharf Photography
Canon CPS USA Member
stephenscharf.com (external link)
Canon 1D MkII, 1D, (ex- 20D),D60, Canon 500/f4 L IS, 300/2.8L, 70-200/2.8L, 100-400/f4-5.6L IS, 17-40L, 28-135 IS, 1.4XII, 2X II, G9, Powershot 45.
Rehuel
Nov 02, 2007 21:10 |  #12
It looks like hand shake to me. You probably got used to the IS on the other lens which is more forgiving. The 24-70 is an amazing lens with great quality but it also picks up every flaw in both subject and photographer. It is also a very heavy lens and takes some getting used to. Place the camera on a tripod and use your timer or a remote to take some pics to see if something is wrong with the lens or not.
Canon 40D/BG-E2N Grip | Canon 30D/BG-E2 Grip | Canon Speedlites 580EXII, 580EX, 430EX (x2) | Canon 100-400mm L | Canon 24-70mm L | Canon 50mm | Tokina 100mm Macro
Click Here and Join the POTN flickr Group Today! (external link) www.flickr.com/photos/​rehuel (external link) www.thedmds.com (external link) http://digitalmastersd​esignstudio.blogspot.c​om (external link)
Hermeto
Nov 02, 2007 21:25 |  #13
I cannot tell about the first shot because there is not enough information, but I am pretty sure that the second one is user error.
Since the sensor area is larger than the mark on the focusing screen, camera focused on the vertical board edge because it has more contrast than the bolt.
Both examples are not well chosen: as already mentioned before, test should be repeated in a more controlled setting.
Papaw
Joined Sep 2004
Nov 02, 2007 21:48 |  #14
The 20D is an excellent camera with great IQ. I wouldn't expect much more IQ from the 40D than the 20D. I agree with Hermeto and imagine the camera is fine.
1D MKIIN 30D 20D and G6
35L 85L 400L 17-40L 24-70L 24-105L 70-200 f/2.8L IS
10-22 f3.5 60 Macro
ronmayhew
Nov 02, 2007 22:07 as a reply to  @ Papaw's post |  #15
My 24-70L sucked until I sent it back to Canon for calibration.
Then it was great.
Try swapping lenses and see what happens.
Canon: 70D, 16-35L, 50mm f/1.4, 85mm f/1.8, 100mm f/2.0, 75-300mm IS, 35-350L :cool:, 135mm f/2.0L, Pro9000 .
Sigma: 70-200mm f/2.8; Alien Bees: B1600
Tamron: 17-50mm, 28-75mm, 90mm fMacro,
12,405 views & 0 likes for this thread, 40 members have posted to it and it is followed by 3 members.
2858 guests, 139 members online
