Thread started 03 Nov 2007 (Saturday) 10:13
Question about tracking and shooting objects moving at high speed
TMR ­ Design
Joined Feb 2006
Nov 03, 2007 10:13 |  #1
I've seen a lot of shots or motorcycle and car racing and I see 2 types of shots. One is where anything and everything in the shot os frozen, and in the other, the subject is frozen but there is a motion blur in the background, as in the stands or the fans behind the track.
What is the technique used? In both scenarios you're tracking and moving the camera with the moving subject so how do you create this effect.
I'm sure anyone that knows what I'm talking about doesn't need to see an example but if anyone does I can point you to a few images that demonstrate both types of shots.
Robert
bildeb0rg
Gallery: 824 photos
Nov 03, 2007 10:18 |  #2
For a little background blur, use a shutter speed of less than 1/250th. The exact effect is dependant on the speed the subject is moving, so this is a ball park figure, and you really need to suck it and see...
GyRob
Nov 03, 2007 10:20 |  #3
To freez everything you need s fast shutter around 1/1500 or above.
to get background motion blur you Pan with the subject at a much slower SS around 1/200 .
Good Panning at a slow SS will make the subject still in relation to the camera but the background will in effect be moving in relation to the camera .
Rob
"The LensMaster Gimbal"
TMR ­ Design
Joined Feb 2006
Nov 03, 2007 10:22 |  #4
bildeb0rg wrote in post #4244408 (external link)
Thanks bildeb0rg
GyRob wrote in post #4244413 (external link)
Rob
Thank you Rob. I thought it was something like that but had no idea of what range of shutter speeds would creat the effect.
Robert
tsaraleksi
Nov 03, 2007 11:05 |  #5
And logically, the faster the subject, the higher the shutter speed that will still blur the background-- ie a distance runner would need a relatively slow speed to blur the background (say, 1/50) , but a race car would be getting good blur at 1/200.
--Alex Editorial Portfolio (external link)
|| Elan 7ne+BG ||5D mk. II ||1D mk. II N || EF 17-40 F4L ||EF 24-70 F2.8L||EF 35 1.4L || EF 85 1.2L ||EF 70-200 2.8L|| EF 300 4L IS[on loan]| |Speedlite 580EX || Nikon Coolscan IV ED||
TMR ­ Design
Joined Feb 2006
Nov 03, 2007 11:13 as a reply to  @ tsaraleksi's post |  #6
That makes perfect sense. Thanks Alex.
Robert
Fotoshooter
Nov 03, 2007 20:16 |  #7
The background blur technique is called panning. To keep a moving subject looking sharp while using a slow shutter speed requires skill. The better you are able to maintain the subject in the same position in the frame while panning, the sharper it will appear. Thus you must move the camera in synchronization with the subject. To obtain a background with a long streaked blur may require a shutter speed of 1/15 sec or slower.
Stephen
Quote: "When your mouth drops open, click the shutter." – Harold Feinstein
1,390 views & 0 likes for this thread, 5 members have posted to it.
2853 guests, 139 members online
