Thread started 04 Nov 2007 (Sunday) 09:30
Time for noise reduction software.
Tapeman
Sliced Bread
Joined Jan 2004
Nov 04, 2007 09:30 |  #1
I just took some shots wide open at 1600 ISO and want to reduce noise in them.
What do you recommend? Noise Ninja? Noiseware? Plug-ins for Photoshop?
I'm using Lightroom and PS3. (Not very well.)
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
Sauk
Nov 04, 2007 09:41 |  #2
Tapeman wrote in post #4249799 (external link)
I used to use Neat Image, but I switched to Noise Ninja. Very very solid! It clears it up, but won't turn them into plastic.
tonylong
...winded
Gallery: 60 photos
Nov 04, 2007 15:33 |  #3
Do you have the latest version of Lightroom? If not, I'd get it, it has some improvements in NR. I'd start with that because it's a bit kinder and gentler. Then, if that doesn't work, well, I have Noise Ninja, but I've seen that remove a lot of detail, so use with care!
If you do use Noise Ninja in PS, try using it on a layer with a copy of your original, rather than on the original itself. That way you can adjust and/or mask parts of the image and keep the original intact.
Tony
Tony
Tony
Tapeman
Sliced Bread
Joined Jan 2004
Nov 04, 2007 15:48 |  #4
Tony, I have version 1.2. I won't buy a noise reduction program if it is only slightly better than what I have already in LR or PS3.
waves
Nov 04, 2007 15:53 |  #5
I would go with Noise Ninja but get the plug in version for PS not the stand alone version. Don't ask me why but the plug in works better than the stand alone version IMO I have both, but like I said the plug in works better!!!
I like cheese
FlyingPhotog
Cream of the "Prop"
Nov 04, 2007 18:07 |  #6
I'll add a vote for Noise Ninja... I too have the plug in for CS3 and it's great.
Pretty cool that it can identify and tweak images by camera body and ISO. Been real happy with it.
Jay
Tsmith
Formerly known as Bluedog_XT
Nov 04, 2007 18:40 |  #7
You need to use the camera profile for the most accurate results with Noise Ninja. Having said that and used both I prefer Imagenomic Noiseware Pro plug in for CS3.
They offer a free stand alone version too that works alright.
Anke
Nov 04, 2007 23:38 |  #8
Another fan here of Noise Ninja.
Anke
René ­ Damkot
Nov 05, 2007 01:47 |  #9
Noiseware (external link) above NN or NI any day...
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Tapeman
Sliced Bread
Joined Jan 2004
Nov 05, 2007 08:39 |  #10
Now I an unsure which program to get.:rolleyes:
FlyingPhotog
Cream of the "Prop"
Nov 05, 2007 10:59 |  #11
Noise Ninja can be d'loaded and demo'd for free. It will put a grid over your image until you buy a license, but at least you can do some pixel-peeping to see how well it works.
Jay
Tapeman
Sliced Bread
Joined Jan 2004
Nov 05, 2007 13:40 as a reply to  @ FlyingPhotog's post |  #12
I think I will try Noise Ninja and Noiseware. Noiseware is almost a hundred bucks!
Free trials are a cool way to compare products.
cdifoto
Don't get pissy with me
Nov 05, 2007 13:43 |  #13
I bought Neat Image. It's decent enough as long as you don't go overboard. I seldom use it anymore though.
bacchanal
Nov 05, 2007 13:54 as a reply to  @ cdifoto's post |  #14
I have Noiseware, and it works well, but I don't use it as much as I used to. I do use it as sort of a quick skin smoother occasionally. I think the key to using any NR software is to not take it too far. In many cases, you don't necessarily need to eliminate the grain (killing detail in the process)...just reduce it a little. Using a layer mask is a good idea too.
PixelMagic
Nov 05, 2007 14:02 |  #15
I use Noiseware too so I can recommend it.
However, I have to ask....you say you're using Photoshop CS3....have you attempted to use the Noise Reduction features of Adobe Camera Raw that is present in both Lightroom and CS3? It has made most NR software obsolete.
Between the new ACR Noise Reduction introduced in version 4.1 and the native Noise Reduction filters in Photoshop itself, I hardly ever have to use third-party NR software. The trick is to begin editing any image - even if its not a RAW format - in Adobe Camera Raw. Then you can open the image as a Smart Object in Photoshop and complete the editing.
2,166 views & 0 likes for this thread, 11 members have posted to it.
1444 guests, 139 members online
