Thread started 04 Nov 2007 (Sunday) 20:08
IN CAMERA SHARPEN ON 1D MARK IIn???
downhillnews
Nov 04, 2007 20:08 |  #1
How many of you use the in camera sharpen? I had it up 3/4 of the way to full and some images came out oversharp after running batches in PS 3? What do you think should it be on at all and if so how much??? I shoot mainly sport type material.
The first has only in camera sharpen.
IMAGE: http://i89.photobucket.com/albums/k206/downhillnews/100-4007.jpg
The second has the batch sharpen by PS??
IMAGE: http://i89.photobucket.com/albums/k206/downhillnews/100-4002-1.jpg
WWW.DOWNHILLNEWS.COM (external link)
WWW.IJWPHOTOGRAPHY.COM (external link)
Phase One Certified Digital Tech
BestVisuals
Nov 04, 2007 20:21 |  #2
I don't own a Mark-something-or-other, but I can tell you that I have my 20Ds set to max sharpen. I found I was adding sharpness in 100% of my photos, so I decided to let the camera do it and save me a step in post.
Canon 5D MK II, 24-105 L, Sigma 16mm fisheye
AdamLewis
Nov 04, 2007 21:26 |  #3
RVsForFun wrote in post #4253255 (external link)
I thought USM or SS was a required step in PP :lol:
Stephen ­ Scharf
Nov 04, 2007 21:29 |  #4
I don't add any sharpening on any cameras, I like to control that in post. I use PhotoKit Sharpener, it has a 3 step workflow, and provides a very fine degree of control with layers.
Stephen J Scharf Photography
Canon CPS USA Member
stephenscharf.com (external link)
Canon 1D MkII, 1D, (ex- 20D),D60, Canon 500/f4 L IS, 300/2.8L, 70-200/2.8L, 100-400/f4-5.6L IS, 17-40L, 28-135 IS, 1.4XII, 2X II, G9, Powershot 45.
AdamLewis
Nov 04, 2007 21:31 |  #5
Stephen Scharf wrote in post #4253775 (external link)
Im with you. I feel that PS sharpens better than the camera does so I just let it get taken care of later. It doesnt add all that much time anyways :)
liza
Nov 04, 2007 21:41 |  #6
AdamLewis wrote in post #4253785 (external link)
Agree completely. What's a few extra seconds for better image quality? Besides, I use high pass sharpening, not USM or in camera.
Elizabeth
Blog
http://www.emc2foto.bl​ogspot.com/ (external link)
downhillnews
Nov 04, 2007 21:41 |  #7
Ok but if I am running batches with like 500 pics in it there will not be any variance as far as what each shot requires? So say it is 90 2 8 and that looks ideal. If I am jumping F's from 2.8 on up to say 8 it will not alter much from image to image??
THANKS
downhillnews
Nov 04, 2007 21:42 |  #8
liza wrote in post #4253845 (external link)
Elizabeth,
Sorry high pass sharpen, what is it???
AdamLewis
Nov 04, 2007 21:55 |  #9
downhillnews wrote in post #4253847 (external link)
THANKS
First off, let me say that Im completely ignorant of the technical workings of how sharpening in-camera or in Photoshop works.
That being said, I dont believe that PS discriminates between that F number the image was taken at when it applies sharpening. I also dont believe that the camera does either.
So, I dont think it really matters. I think they both blindly apply sharpening to pixels and have no regard for any other information.
AdamLewis
Nov 04, 2007 21:55 |  #10
downhillnews wrote in post #4253856 (external link)
Elizabeth,
Im curious as well...
liza
Nov 04, 2007 22:03 |  #11
I use Kevin Kubota's "Custom High Pass" action for sharpening. It utilizes the high pass filter for sharpening.
Example:
Elizabeth
Blog
Hermeto
Nov 04, 2007 22:18 |  #12
Same here!
I found PK Sharpener to be the best for my workflow.
Both OP images look over sharpened, IMHO.
Dan-o
Nov 04, 2007 22:33 |  #13
Highpass:
Duplicate layer
filter>other>highpass
Enter a radius (Play with the numbers anywhere from .5 to 2)
Now in the layers pallette you have three boxes there click the expand arrow were it says Normal and select overlay. I also use Vivid a lot. Now click the Opacity slider and drag it back and forth. Flatten when you are done. Create an Action for this and it is very fast.
Danny.
DMunsonPhoto (external link)
Cycling Illustrated (external link)
FaceBook Page (external link)
dpastern
Nov 09, 2007 20:01 |  #14
I do a small amount of sharpening in DPP or C1 Pro, and the rest in Photoshop. I typically apply less sharpening in Photoshop than many here, with my settings being around 30%, 0.3 pixels and 3 for the threshold. I adjust on a per image basis. I also use the smart sharpen filter as part of my standard workflow - converting to LAB mode to do this to avoid fringing affects from sharpening etc..
Dave
cdifoto
Don't get pissy with me
Nov 09, 2007 20:45 |  #15
AdamLewis wrote in post #4253949 (external link)
It doesn't if you're batch sharpening. If you're taking the time to adjust on a per-image basis on the computer then obviously it's better to leave sharpening at a low level in-camera.
1,833 views & 0 likes for this thread, 10 members have posted to it.
2879 guests, 135 members online
